| Thread Closed |
DC biasing using voltage divider |
Share Thread | Thread Tools |
| Jan30-06, 04:07 PM | #1 |
how do I use a voltage divider to biasing a signal that goes from -5v to 5v so that it goes from 0 to 2.5?
| Jan30-06, 04:14 PM | #2 |
It's not possible. A voltage-divider can only change a signal's amplitude, but cannot change its mean value.
You're hoping to put a signal of 0V (the midpoint of -5 to 5V) and get out a signal of 1.25V. That'd be quite a feat for nothing but a couple of resistors. You'll need to use an op-amp, or at least capacitively-couple your input to a bias network (perhaps made out of a voltage divider). - Warren |
| Jan30-06, 04:22 PM | #3 |
Mentor
Make a 3-resistor network with two resistors in series from 10V to -10V. Couple your input voltage into the middle of these two resistors using another resistor. Make the top resistor 10K, the bottom resistor 20K, and the input resistor 10K. Now vary the input voltage between -5V and 5V, and calculate what happens at the output (the intersection of the 3 resistors). Do you see a way to get the voltage offset and scaling that is asked for in the problem? Keep in mind that you can set different voltages on the top and bottom of the voltage divider if that helps. Just write some simultaneous equations.... |
| Jan30-06, 04:34 PM | #4 |
Mentor
BTW, in a real world application, you would need to consider the source impedance and the input impedance of whatever circuit came next after the voltage biasing network. In the case of this homework problem, you can probably assume that the output impedance of the source voltage is negligibly low, and the input impedance of whatever is using the output voltage is very high.
| Thread Closed |
| Thread Tools | |
Similar Threads for: DC biasing using voltage divider
| Voltage Divider Help | Electrical Engineering | 1 | ||
| Equation with a voltage divider | Engineering, Comp Sci, & Technology Homework | 8 | ||
| Potentiometer/voltage divider?!?? | Electrical Engineering | 5 | ||
| voltage divider problem | Electrical Engineering | 2 | ||
| How do voltage-divider & current-divider work; physically? | General Physics | 2 | ||
