Thread Closed
voltage divider problem
Share Thread
Mar6-06, 11:52 AM   #1
I designed a circuit that has an analog signal conditioning portion, and a digital circuit to make some measurements on the signal.
The analog circuit is powered by 15V supplys, thus the output is a 0-15V square wave. The digital circuit needs a 0-5V input. I tried using a voltage divider on the output of the analog circuit to bring the voltage down to a 0-5V square wave, which worked fine. When I connected the output of the voltage divider to a digital device, the result was the signal was offset. The offset was high enough that the digital device was only reading a high instead of a changing signal.
I used seperate power and grounds for the analog circuits.
Any ideas on how to fix this?
PhysOrg.com engineering news on PhysOrg.com
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
>> Faster, more precise airstrikes within reach
>> How smart technology could change public transit
Mar6-06, 12:46 PM   #2
Mentor
Have you figured out the source of the offsets yet? Look at the input current specications for the digital logic, and the output drive specs for the previous analog buffer stage.
Instead of a voltage divider, you could instead just use a clipper circuit. A resistor in and a diode clamp to 5V will get you a maximum of 5.6V or so. Just be sure that the digital logic input isn't inclined to latch up with the extra 0.6V input for the high signal.
You could also use something like an open-collector stage to convert from the 15V domain to the 5V domain. You'll get an inversion out of an open-collector stage, though, so keep that in mind.
Mar6-06, 12:52 PM   #3
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
You might need to buffer the output of the voltage divider, or use larger-value resistors.
- Warren
Thread Closed
Similar Threads for: voltage divider problem
Thread Forum Replies
Voltage Divider Help Electrical Engineering 1
Equation with a voltage divider Engineering, Comp Sci, & Technology Homework 8
Potentiometer/voltage divider?!?? Electrical Engineering 5
DC biasing using voltage divider Electrical Engineering 3
How do voltage-divider & current-divider work; physically? General Physics 2
