Is It Safe to Connect the Bare Ground Wire to the Metal Box for 240V Machinery?
  • Thread starter Thread starter frogdogbb
This discussion addresses the safe connection of the bare ground wire to a metal box for 240V machinery. It emphasizes that the bare ground wire should be connected to the chassis of the 240V device and then to the ground bar in the service panel, not the neutral bus bar. The conversation highlights the importance of adhering to electrical codes that prohibit sharing ground and neutral wires for 240V appliances, particularly in the context of newer dryers that utilize four-prong outlets. Proper grounding is essential for electrical shock protection and compliance with safety standards.
  • Understanding of 240V electrical systems
  • Familiarity with electrical codes regarding grounding and neutral connections
  • Knowledge of wiring configurations for three-prong and four-prong outlets
  • Basic electrical safety practices
  • Research the National Electrical Code (NEC) regulations on grounding and bonding
  • Learn about the differences between three-prong and four-prong outlet configurations
  • Study the implications of using 12-3 wiring for 240V appliances
  • Investigate best practices for installing disconnects at electrical meters
Electricians, electrical engineers, DIY homeowners, and anyone involved in the installation or maintenance of 240V machinery and appliances.
frogdogbb
I am not sure how to approach this problem with my household electrical distribution box. My main panel inside the house is located away from the wall where the meter is. I know I have to have a disconnect at the meter which I am going to install where the neutral and ground are tied together, also the neutral and ground will not be tied together at the breaker box. My question is this...
If I have 240V machinery that has a three prong plug where the neutral is what is part of the metal part of the recepticle and the box is metal now the box is also part of the neutral. If I am using 12-3 what should I do with the bare ground leave it unconnected or tie it to the box. I would think leave it unconnected otherwise I just tied the neutral to the ground. But is there sufficent electrical shock protection? I know newer dyers have 4 prong outlets how does this work and why?
If the 240 volt device does not have any current normally flowing in what you refer to as a neutral then it really isn't a neutral. It is a ground. Connect it to the chassis of your 240 volt device and connect the other end to the ground bar in your service panel. NOT the neutral bus bar. The code no longer allows you to share a gound and neutral on 240 volt appliances such as a clothes dryer where there will be current normally carried in the neutral wire. In the case of the clothes dryer the motor runs on 120 volts so there is current in the neutral wire.
  • · Replies 32 ·
  • · Replies 79 ·
  • · Replies 35 ·
16K
