| Thread Closed |
Help graphing the equation of an ellipse. |
Share Thread | Thread Tools |
| Jul8-06, 03:49 AM | #1 |
I’m having trouble graphing this equation:
16x^2+9y^2=144 I have entered it into both my Algebrator program and the quickmath.com website. They both gave the same graph of the ellipse. In each case the major axis was vertical. With the Algebrator program it simplifies the above equation into (quickmath.com didn’t do this): (x^2)/9 + (y^2)/16 =1 This makes sense; just divide each side by 144 to make it all equal to 1. However, my textbook says that a^2 is always >/= to b^2. So the simplified equation seams to be wrong in the first place. If I try and use it to graph an ellipse myself then I find that the major axis would actually be shorter than the minor axis! According to my textbook when the x term comes first the direction of the major axis is horizontal not vertical as was graphed by both programs. In either case (horizontal or vertical form of the equation) the first term’s denominator is supposed to be a^2, and the next term’s denominator is b^2. That would mean that a=3 and b=4 and the length of the major axis would be 2a (6) and the minor would be 2b (8). So this doesn’t make any sense, am I supposed to just graph this and ignore the fact that 2a is hardly “major” and 2b is hardly “minor”? I don’t know of any other way of doing this problem. Any help would be much appreciated. Thanks, Alan |
| Jul8-06, 05:46 AM | #2 |
I don't understand your problems.
You have: [tex](\frac{x}{3})^{2}+(\frac{y}{4})^{2}=1[/tex] It should be very easy for you to find out what is major and minor axes in this form. |
| Jul8-06, 06:23 AM | #3 |
[tex](\frac{x}{3})^{2}+(\frac{y}{4})^{2}=1 \Leftrightarrow (\frac{y}{4})^{2}+(\frac{x}{3})^{2}=1[/tex] Where [itex]\Leftrightarrow[/itex] means equivelent or "the same as". So the implicit function for the ellipse is independant of the order of the x and y's. This is the basic law of addition where x+y is the same as y+x. |
| Jul8-06, 06:32 AM | #4 |
Help graphing the equation of an ellipse.-Alan |
| Jul8-06, 06:35 AM | #5 |
The major axis is the greatest one; that is not dependent upon whether the associated variable is called "x" or "y". In this case, the major axis is, indeed, along the vertical. |
| Jul8-06, 06:40 AM | #6 |
According to my textbook the major axis is 2a. The minor is 2b. a^2 is 9, is it not? b^2 is 16, is it not? Then it would be reasonable to conclude that 2a=6 and 2b=8, which doesn't make much sense.
And according to my textbook the form of the equation x^2/a^2 + y^2/b^2 = 1 has the major axis horizontal. My equation is in that form. |
| Jul8-06, 06:44 AM | #7 |
No, that is not what your textbook says. Read it again.
| Jul8-06, 06:46 AM | #8 |
Read your textbook again! The "major" axis is always the longer of the two axes, the minor axis is the shorter (That's why they call them "major" and "minor"!
) whether that longer axis is vertical or horizontal. However, the longer axis may be eithervertical or horizontal (or even at an angle but you probably won't see those in this course). If the major axis is horizontal then the "a" in [itex]\frac{x^2}{a^2}+ \frac{y^2}{b^2}= 1[/itex] will be larger than the "b". If the major axis is vertical then b will be larger than a.By the way, since the title of this was "Help graphing the equation of an ellipse", here's a quick way to do it by hand: with the ellipse equation in "standard form", [tex]\frac{x^2}{a^2}+ \frac{y^2}{b^2}= 1[/tex] draw vertical lines through (a,0) and (-a,0) and horizontal lines through (0,b) and (0,-b). Now sketch your ellipse so that it is tangent to those lines at (a,0), (-a,0), (0,b), and (0,-b). |
| Jul8-06, 06:47 AM | #9 |
Yes it does! I've had it in front of me the whole time.
| Jul8-06, 06:52 AM | #10 |
Please check the Wikipedia article on the ellipse. Of importence in this case is:
| Jul8-06, 07:07 AM | #11 |
This is a screenshot of what my book says.
A screenshot of the Algebrator graph of my equation. |
| Jul8-06, 07:23 AM | #12 |
Note that your textbook uses the convention that "a" is ALWAYS the largest number, "b" the least.
In many computer applications, however (and most math books), "a" is used for the denominator in the x-fraction, whether or not "a" is the largest number. Either of these conventions is, by its own, perfectly acceptable, but you must not mix them together!! Furthermore, pay particular attention to what your textbook calls "standard form". Given: [tex]\frac{x^{2}}{3^{2}}+\frac{y^{2}}{4^{2}}=1[/tex] This is NOT standard form according to your textbook, but is standard form for most other books! Standard form for your textbook is gained by interchanging the x-and y-terms: [tex]\frac{y^{2}}{4^{2}}+\frac{x^{2}}{3^{2}}=1[/tex] |
| Jul8-06, 07:44 AM | #13 |
why did you switch the two? I'm confused.
| Jul8-06, 07:49 AM | #14 |
1. The sum of two numbers is the same, irrespective of the order of those numbers (3+4=4+3, 4.555557+3.01=3.01+4.555557 and so on)
Thus, we have the identity (not equation!): [tex]\frac{x^{2}}{9}+\frac{y^{2}}{16}=\frac{y^{2}}{16}+\frac{x^{2}}{9}[/tex] 2. Your book requires that in STANDARD FORM, the number with the largest denominator is to be written first in the equation. |
| Jul8-06, 06:34 PM | #15 |
sooo... I don't determine what is a^2 and what is b^2 by what term they appear under? I just look at the denominator's and call the bigger one a^2?
WTF! Why couldn't the book just have said that! I don't know how I would have seen that if I didn't ask. I think that I hate my textbook... Now that I've re-read the replies I think that's what you guys have been saying all along. Here I thought you guys were misunderstanding me, and it was actually the other way around! So, the graph is right; my equation is just the same as saying y^2/16 + x^2/9=1, and a^2 is actually bigger than b^2 like it is supposed to be! I totally didn’t see that until arildno’s last post with the identity (not) equation side by side. Thanks, Alan |
| Jul8-06, 06:46 PM | #16 |
Advice: Read your book CAREFULLY. Try to think over: Have I really understood this? Glad I was of some assistance!
| Jul9-06, 06:05 AM | #17 |
[tex]\frac{x^2}{a^2}+\frac{y^2}{b^2}= 1[/tex] with "major axis horizontal" under it. The other column has [tex]\frac{y^2}{a^2}+ \frac{x^2}{b^2}= 1[/tex] with "major axis vertical" under it. [tex]\frac{x^2}{a^2}+ \frac{y^2}{b^2}= 1[/tex] allowing either a or b to be larger. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Help graphing the equation of an ellipse.
| equation for an ellipse | Precalculus Mathematics Homework | 8 | ||
| the equation for any set of lines passing through an ellipse with the same slope | Calculus & Beyond Homework | 7 | ||
| Equation of ellipse in 3D | General Math | 11 | ||
| differentiation of ellipse equation | Calculus & Beyond Homework | 2 | ||
| ellipse,polar equation 3D | Astrophysics | 0 | ||
