How can we simplify the integral of a step function with a derivative?
The integral of a step function U(x) and its derivative δ(x) can be simplified using the sifting property of the Dirac delta function. Specifically, for the integral ∫-26(x² - 8)δ(x)dx, the limits of integration can be adjusted as long as they include zero. The result of the integral is definitively -8, as the delta function evaluates the expression at x = 0, yielding -8. The integral can be split into segments, confirming that the value remains consistent across different limits that encompass zero.
  • Understanding of the Heaviside step function U(x)
  • Knowledge of the Dirac delta function δ(x) and its properties
  • Familiarity with integral calculus and limits of integration
  • Ability to manipulate and split integrals in calculus
  • Study the properties of the Dirac delta function in detail
  • Learn about the Heaviside step function and its applications in signal processing
  • Explore advanced techniques in integral calculus, including improper integrals
  • Investigate the use of delta functions in physics and engineering contexts
Mathematicians, physics students, engineers, and anyone interested in advanced calculus and the applications of step functions and delta functions in various fields.
courtrigrad
Suppose [tex]U(x)[/tex] is the step function and [tex]\delta(x)[/tex] is its derivative. Find [tex]\int^{6}_{-2}(x^{2}-8)\delta(x)\dx[/tex]. I know [tex]\delta(x) = 0[/tex] for all [tex]x[/tex] except [tex]x = 0[/tex]. So at [tex]x = 0[/tex] [tex]v(x) = - 8[/tex]. After this step, how do we get [tex]\int_{-2}^{2}(x^{2}-8)\delta(x)\dx +\int^{6}_{2}(x^{2}-8)\delta(x)\dx = -8 + 0[/tex]. How do you get the limits of integration?
Thanks
If by step function you mean
[tex]U(x)=\left\{\begin{array}{cc}0,&\mbox{ if }x\leq 0\\1, & \mbox{ if } x\geq 0\end{array}\right.[/tex]​
(a.k.a. the Heaviside step function) then [tex]\frac{d}{dx}U(x) = \delta (x)[/tex] is a Dirac delta function which has the so-called snifting property, that is
[tex]\int_{-\infty}^{\infty}f(x)\delta (x) \, dx = f(0)[/tex]​
so the limits of integration don't matter (so long as they contain zero) and the value of the integral is -8.
Thanks
Remember that you can split up the integral. So,
[tex]\int^{6}_{-2}(x^{2}-8)\delta(x)\dx = \int_{-2}^{0}(x^{2}-8)\delta(x)\dx = \int_{0}^{6}(x^{2}-8)\delta(x)\dx[/tex]
[tex]\int^{6}_{-2}(x^{2}-8)\delta(x)\dx = \int_{-2}^{0}(x^{2}-8)\delta(x)\dx = \int_{0}^{1}(x^{2}-8)\delta(x)\dx =\int_{1}^{6}(x^{2}-8)\delta(x)\dx[/tex]
or however you want (within the bounds of the original limits, etc...). So the integral equals 0 for some limits of integration, it will hit 0 and the sifting property kicks in, and then the integral equals 0 again.
  • · Replies 105 ·
13K
