How long can a Snickers bar power the human brain?
The discussion revolves around calculating how long a Snickers bar can power the human brain, which consumes approximately 21.9 watts under normal conditions. The original poster attempts to convert the energy content of the Snickers bar, measured in calories, into a time duration based on the brain's power consumption.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the conversion of calories to joules and the implications of the energy content of the Snickers bar on the brain's power requirements. Questions are raised about the accuracy of the original calculations and the assumptions made regarding energy consumption.
Some participants have provided guidance on the calculations and noted potential errors in the original poster's approach. There is an acknowledgment of the need to clarify the conversion factors and the implications of the energy calculations. Multiple interpretations of the problem are being explored, but there is no explicit consensus on the correct answer yet.
Participants note the importance of understanding the distinction between food calories and physics calories, as well as the potential need for additional energy during more demanding cognitive tasks, such as exams.
UCrazyBeautifulU
The human brain consumes about 21.9 W of power under normal conditions, though more power may be required during exams. How long can one Snickers bar (280 cal per bar) power the normally functioning brain?[/B] (Note: The nutritional calorie, 1 Cal, is equivalent to 1000 calories (1000 cal) as defined in physics. In addition, the conversion factor between calories and joules is as follows: 1 Cal = 1000 cal = 1 kcal = 4186 J.)
I keep getting the answer 53.52 seconds after I do the conversion and use the formula P = W/t
However, 53.52 seconds isn't the correct answer (LON CAPA did not accept it), anyone else have any ideas on this one?
You did the problem almost correctly. Read carefully that a food calorie is actually 1000 calories.
Also, think about the 53.52 seconds for a brain to run on a snickers bar; you'd need to eat about 60 of them just to make it through an exam at that rate :) The actual answer makes more sense.
You are off by an order of magnitude. How many Joules of energy is stored in that Snickers bar?
thanks so much, you guys really helped me out! I knew it didn't make sense, but I couldn't figure out what I was doing wrong.
12K
9K
