Thread Closed
BJT biasing circuits
Share Thread Thread Tools
Nov23-06, 06:52 AM   #1
We've base biased circuit, voltage divider, emitter bias, and collector feed back bias...I'm looking for resources, to compare those 4 types, what are the advantages of each type, why is it used, and where...
I know BJT's work in amplifiers, but i need more detail concerning those different biasing circuits.
Thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Nov23-06, 09:06 AM   #2
This sounds like a homework question. We will not be doing your homework for you. If you've covered all of the above mentioned schemes in lab/class then wasn't it covered why each one is used or were you sleeping through that part? When I was in school for electronics those biasing schemes were covered and part of the lecture was which one was used where, and why.
Nov23-06, 10:39 PM   #3
Mentor
Moved to homework forums.
Wanderer, what is the class that you're taking (what level, what title, what subject matter)? What learning resources do you have so far? What is your textbook. As supernova says, you need to show us your work and thinking so far in order for us to help you.
Nov24-06, 01:21 PM   #4
No text book, that part was not covered, i've no resources, it's not homework, i'm having an electronic devices class, diodes, and transistors...That's why i'm asking, it's nothing i know of yet, just some titles.
I'm studying nuclear engineering, we used to have 2 courses, electronic circuits and digital circuits, but now we've all in one, covering the devices we may use, we are not getting deeper into this.
Nov24-06, 05:02 PM   #5
Mentor
You might try wikipedia.org as a starting point. Look up transistors and amplifiers and diodes and such -- there are reasonable introductions to subjects like that at wiki.
Nov25-06, 06:10 AM   #6
I've tried that, there's nothing i need there, i want to learn more about the BJT biasing circuits, those 4 types, specifically i thought i asked for that.
I don't need introductions for transistors and diodes, i need the answer of a specific question, i've searched the internet for what i wanted, but i didn't get enough.
So, thx for the help anyway!
Nov26-06, 11:02 PM   #7
Mentor
Okay. I googled bjt bias circuit and got lots of great hits. Here's one of the first ones:
http://engr.astate.edu/jdg/Electroni...orBiasing.html
If googling bjt bias circuit doesn't work for you, what other learning resources do you have available? When I was in school, there was a textbook that went with each class. If you are learning this all on your own, maybe folks can recommend good textbooks for you to check out in your local technical library.
Nov27-06, 06:21 AM   #8
Well, i asked the professor, she thinks we only need to know how to make our calculations, which isn't enough.
So that's why i was looking for more details, i found something in a nearby used book store today, i'm working on it...
Thx.
Thread Closed
Thread Tools
Similar Threads for: BJT biasing circuits
Thread Forum Replies
MOSFET DC Biasing Design Electrical Engineering 3
Biasing Introductory Physics Homework 1
IC Biasing with Current Sources Electrical Engineering 1
common emitter amplifier circuit using feedback biasing Engineering, Comp Sci, & Technology Homework 1
DC biasing using voltage divider Electrical Engineering 3
