Thread Closed
Cathode ray tube?
Share Thread
Jan2-07, 05:45 PM   #1
Cathode ray tube?
Why is the end of the hot filament where negatively charged electrons are being fired called the cathode end. 'cat' in chemistry means positive, I assume the same goes in physics as well?
PhysOrg.com physics news on PhysOrg.com
>> Is there an invisible tug-of-war behind bad hearts and power outages?
>> Penetrating the quantum nature of magnetism
>> Rethinking the universe: Groundbreaking theory proposed in 1997 suggests a 'multiverse'
Jan2-07, 10:15 PM   #2
Mentor
http://www.av8n.com/physics/anode-cathode.htm
Jan3-07, 07:17 AM   #3
I can't access this site. It's 'Forbidden'.
Jan3-07, 07:50 AM   #4
Cathode ray tube?
cathode is called cat or positive because it is emitting or "losing electrons" thus making it positive or cat
Jan3-07, 07:51 AM   #5
remember thermo ionic emission
Jan3-07, 03:49 PM   #6
Quote by hustleberry View Post
What is thermo ionic emission?
Jan3-07, 04:27 PM   #7
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Thermionic emission is the emission of charged particles from a charged surface (usually metal), which is caused by the vibration energy of the particles overcoming the electrical potential holding them to the surface. An example of this would be your cathode ray tube where a charged filament is heated (by passing a large current through it), the electrons on the surface of the filament (remember charge always resides on the surface of a conductor) gain enough thermal energy to 'break free'.
For more detail google: Thermionic Emission
Jan4-07, 06:40 AM   #8
So that is the main reason. The receiving end is receiving the electrons hence will be made more negative so that end is called the anode.
Jan4-07, 06:47 AM   #9
Mentor
Quote by pivoxa15 View Post
That doesn't make any sense either. An electron will move from a low electrostatic potential to a high potential. It has nothing to do with something being negative or positive. I could have the electrons coming out of a conductor at -10 V and it will still be "attracted" to a conductor at - 5 V, because that latter conductor is at a higher potential. The difference in the potential will create a potential gradient, thus, electric field.
At some point, one should stop getting bogged down with the "name" given to something. If you understand what is going on, you can call it anything you like.
Zz.
Thread Closed
Similar discussions for: Cathode ray tube?
Thread Forum Replies
Cathode Ray Tube Introductory Physics Homework 1
cathode ray tube General Physics 2
Cathode Ray Tube Introductory Physics Homework 4
Cathode Ray Tube Classical Physics 9
Cathode ray tube Introductory Physics Homework 3
