Calculating Barrier Penetration with Proton KE & V
  • Context: Undergrad
  • Thread starter Thread starter zeta101
    Barrier Penetration
This discussion focuses on calculating barrier penetration of protons with kinetic energy (KE) expressed in electronvolts (eV) and the implications of barrier height given in volts. The confusion arises from converting volts to energy, where the correct approach is to multiply the barrier height in volts by the charge of a proton to express it in joules. The conversation highlights that working in eV is more convenient, and emphasizes the importance of understanding quantum mechanics principles, particularly the wave function behavior in relation to barrier penetration as described by Schrödinger's equation.
  • Understanding of kinetic energy in particle physics
  • Familiarity with quantum mechanics, specifically Schrödinger's equation
  • Knowledge of energy conversion from volts to joules
  • Basic concepts of wave functions and barrier penetration
  • Study the principles of quantum tunneling and barrier penetration
  • Learn about the transmission coefficient in quantum mechanics
  • Explore the implications of wave functions in potential barriers
  • Review energy unit conversions, specifically between eV and joules
Physics students, researchers in quantum mechanics, and anyone studying particle behavior in potential barriers will benefit from this discussion.
zeta101
I have a question to do but I am a bit confused about one thing. It invloves protons penetrating a barrier. The protons ae quoted to have a KE in the units of eV (which i will have to convert to joules in order to work in SI units). However the barriers height is given in volts. I assumed this height should be in the units of energy so i multiplied the heigh (in volts) by the charge of a proton/electron, however i get a silly answer at the end...
The formula i am using is for the transmission coeff, it involves a sinh squared term, its too complicated to write here, i have seen a website with it but i can't find the link, however i don't think this is the problem...
thanks for any replies
to clarify the "silly answer" is not to do with the volts expressed as energy but its to do with the question i have to do...
zeta,
I'm confused about what is confusing you. It seems that you never explicated your confusion.
You don't have to work in Joules. In fact, it would probably be more convenient to work in eV (as evidenced by the potential being given in V). I will assume that the protons have less energy than the barrier height? So, maybe you're confused by how they get through? I will also assume that the barrier has some finite width? In this case, the protons get through because they are already through to begin with. That is, their wave function exists on the other side of the boundary because it satisfies Schroedinger's eq. that way.
Maybe your confused by getting a negative kinetic energy inside the barrier potential? That's normal.
