Polchinski Excercise Question - delta function
The discussion revolves around a problem from Polchinski's exercises concerning the mathematical properties of the delta function, specifically in the context of complex analysis and two-dimensional integrals. Participants explore the relationship between the delta function and the integral of a test function involving the logarithm of the squared modulus of a complex variable.
  • Some participants discuss the relationship between the delta function and the integral of a test function, noting that the defining property of the delta function is that it picks out the value of the function at zero.
  • There is a question regarding the appearance of a squared delta function in the result, with some suggesting that this arises from integrating over both the variable and its conjugate.
  • Participants clarify that the squared nature of the delta function does not imply that the test function itself is squared, but rather relates to the dimensionality of the integration.
  • Some express uncertainty about the general method of testing expressions involving delta functions by integrating them with test functions to see if they yield the appropriate values.
  • One participant mentions that the exercise is crucial for proving that the normal ordered product is a harmonic function, which is significant for developing the operator product expansion in physics.
  • There is a critique of the use of operator valued distribution functions without integral signs, suggesting that this practice is problematic from a mathematical standpoint.
Participants generally agree on the properties of the delta function and its relation to integrals, but there are nuances regarding the interpretation of the squared delta function and the implications of dimensionality in integration. The discussion remains somewhat unresolved regarding the broader implications and methods of working with delta functions.
Participants express varying levels of familiarity with the mathematical treatment of delta functions, indicating potential gaps in foundational knowledge that may affect their understanding of the discussion.
selfAdjoint
Staff Emeritus
Dearly Missed
I am going again over Polchinski's excercises, trying to work them and using http://schwinger.harvard.edu/~headrick/polchinski.html when I get stuck. In problem 2.1, P. wants us to show that
[tex]\partial \bar{\partial} ln \vert z \vert^2 = 2 \pi \delta^2(z,\bar{z})[/tex]
and Headrick, introducing a test function f(z) under the integral sign,
[tex]\int_R d^2z \partial \bar{\partial} ln \vert z \vert^2 f(z)[/tex]
eventually gets
[tex]\partial \bar{\partial} ln \vert z \vert^2 = 2 \pi f(0)[/tex]
Can anybody spell out for me how this arbitrary f(o) is the delta function?
the defining characteristic of the delta function is exactly this property you show above:
namely
[tex]\int\delta(x)f(x)=f(0)[/tex]
any function(al) for which this is satisfied for an arbitrary f is the (unique) delta function
so f(0) isn't the delta function, it is the result of integration with a delta function
Thanks lethe. You notice the answer is a squared delta function, but Headrick's test function isn't (explicitly) squared. How does that work?
i think that 2 in the exponent just indicates that you integrate over z and z*. it's a two dimensional delta function
just like we write the 3 dimensional dirac delta
[tex]\delta^3(\mathbf{r})[/tex]
in other words, just because the delta function is squared, it doesn't mean the function gets squared. for example, we have:
[tex]\int\delta^3(\mathbf{r})f(\mathbf{r})d^3\mathbf{r} = \int\delta(x)\delta(y)\delta(z)f(x,y,z)dx\ dy\ dz=f(0,0,0)[/tex]
OK, I think. So in this two dimensional case, we know the delta gets squared because of the double integration of the double derivative. But it still just picks out f(0) from the test function. Have I got that right?
Afterthought: Would it be a general method to test any expression with a delta in it by putting it under an appropriate integral with a test function and seeing if it picks out the appropriate value of the function? I never had any course work in deltas so I'm kind of flying blind here.
yes. i am thinking of the function as a function of z and z*, except that the functional dependence of a holomorphic on z* is trivial, so that factor of the delta function integrates away trivially.
yes: by definition, two expressions with delta functions in them are defined to be equal if, when you integrate them, you pick out the appropriate values.
Thanks a lot, Lethe. I am clear on that. This exercise turns out to be a key step in proving that the normal ordered product is a harmonic function, which is in turn key to developing the OPE for the [tex]X^{\mu}[/tex] physics.
Btw, it drives me nuts how physicists insist on using the above eqn (the first one from SA).
A bare operator valued distribution function ! Horror!
Put an integral sign around both sides, and then its well defined, and all mathematicians may rest easy!
Yeah, and the operator product expansion is an "operator" equation. Only meaningful up to expectation. Abus de langage. You just have to get used to it.
11K
