Thread Closed
Equivalent Resistance
Share Thread Thread Tools
Mar26-07, 06:10 PM   #1
Figure 27-33 (attatched) shows five 5.00 [tex]\Omega[/tex] resistors. (Hint: For each pair of points, imagine that a battery is connected across the pair.)
(a) Find the equivalent resistance between points F and H.
(b) Find the equivalent resistance between points F and G.
2. Relevant equations
For resistors in parallel:
[tex]R_{eq}=(\sum \frac{1}{R_i})^{-1}[/tex]
For resistors in series:
[tex]R_{eq}=\Sigma R_i[/tex]
3. The attempt at a solution
I solved part (a) by realizing that Resistors 1 and 2 are in series, Resistors 4 and 5 are in series, and both pairs are simultaneously in parallel with Resistor 3.
Thus:
[tex]R_{eq}=(\frac{1}{R+R}+\frac{1}{R+R}+\frac{1}{R})^{-1}[/tex]
[tex]R_{eq}=(\frac{1}{10}+\frac{1}{10}+\frac{1}{5})^{-1}=2.5[/tex]
So far, so good.
But for part (b), I can't come up with the correct combination. I said that Resistors 3 and 5 are in series, and they are in parallel with resistor 4. Resistors 1 and 2 are in series, but I don't see how they fit in with the rest of the circuit. I tried treating them as parallel to Resistors 3&5 and Resistor 4, and got 2.5 Ohm (wrong answer). I tried treating them as in series with Resistors 3&5 and then set all four of those resistors parallel to Resistor 4, and got 4 Ohm (still wrong).
Looking at it again, I just get more confused, because 1&2 join the circuit IN THE MIDDLE of the 3&5 series.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Mar26-07, 07:03 PM   #2
Recognitions:
The series combination R1+R2 is in parallel with R3, and that parallel combination is in series with R5. *That* series combination is in parallel with R4.
Mar26-07, 08:18 PM   #3
Thank you very much, that gets the right answer of 3.125 Ohm!
Do you know of a way to figure that out with as little spatial reasoning as possible? (I was the student who could do nearly everything in geometry except see the corresponding angles without turning either my head or the diagram.)
Mar27-07, 04:24 AM   #4
one way is to imagine where the current is going. the shortest route from F-G is direct via R4. another path is R3+R5, which are in series and together, are parallel to R4. next, R1+R2 is parallel to R3, so we revise our calculations for R3+R5.
May3-07, 02:29 PM   #5
Hey, Zuku.
I looked at Marcusl's (wonderful!) explenation and translated it into equations.
Must work step by step. I'm not sure how to translate this symbolically; I'll try this, and you'll tell me if it makes any sense at all.
[tex]R_{eq}=R_1+R_2[/tex]
[tex]R_{eq}=((R_1+R_2)^{-1}+R_3^{-1})^{-1}[/tex]
[tex]R_{eq}=((R_1+R_2)^{-1}+R_3^{-1})^{-1}+R_5[/tex]
[tex]R_{eq}=((((R_1+R_2)^{-1}+R_3^{-1})^{-1}+R_5)^{-1}+R_4^{-1})^{-1}[/tex]
Then shove in 5 for R, and keep very close track of the inverses, and get a numerical answer.
May3-07, 03:12 PM   #6
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Quote by mbrmbrg View Post
Quote by marcusl View Post
I don't see that R5 is in series or in parallel with anything in this circuit.... unless G is not connected to anything else but R4 and R5. The problem may have to make this explicit.
(And it's possible [especially with all of the resistors having the same value] that you get the correct numerical answer with the wrong physical reasoning.)
May3-07, 03:14 PM   #7
Quote by robphy View Post
For part a:
start at point F. The current must be split through three parallel tracks in order to get to point H.
For part b:
If they don't go through R5, how else will R1, R2, and R3 be connected to point G?
May3-07, 03:26 PM   #8
Recognitions:
For part a:
For part b:
I see now that I think the problem is not worded well... or the picture allows some ambiguity.
I would have preferred something like:
Consider five resistors arranged as follows (without any leads running out to the edge of the image). Now ask what is the equivalent resistance between some pair of nodes [assuming nothing is connected to the remaining node]. I think the leads running to the edge of the image suggest that something else may be connected. If so, then you'd have a three-terminal device and these methods won't work. See http://en.wikipedia.org/wiki/Analysi...stive_circuits
Thread Closed
Thread Tools
Similar Threads for: Equivalent Resistance
Thread Forum Replies
Equivalent Resistance Introductory Physics Homework 1
Equivalent Resistance Advanced Physics Homework 0
Equivalent resistance Introductory Physics Homework 1
Equivalent Resistance question HELP!!! Introductory Physics Homework 2
equivalent resistance Introductory Physics Homework 5
