Cos(arcsin(-1/3)) how to do it by hand?
  • Thread starter Thread starter HappMatt
    hand
The discussion revolves around the problem of calculating cos(arcsin(-1/3)) without the use of a calculator. The subject area includes trigonometric functions and their inverses, particularly focusing on the relationship between sine and cosine through right triangles and the Pythagorean identity.
  • Participants explore different methods to find cos(arcsin(-1/3)), including constructing a right triangle and applying the Pythagorean identity. Some participants question the necessity of using a calculator and discuss the implications of the problem's constraints.
There are multiple approaches being discussed, with some participants suggesting the triangle method as a straightforward way to solve the problem. Others have noted the general formula for cos(arcsin(x)) and its application to the specific case. While there is no explicit consensus, the conversation is productive, with participants sharing insights and methods.
Participants mention the challenge of solving the problem without a calculator or other aids, indicating a focus on manual calculation methods. The original poster expresses uncertainty about the best approach given the constraints of the homework assignment.
HappMatt
cos(arcsin(-1/3)) how to do it by hand??
Solve without a calculator
cos(arcsin(-1/3))
now i have fount the solution to be (-2/3)(2^(1/2)) now not only did my calculator come up with that but between the SSS formula and pythagorean formula( i think is what we cal it, a^2+b^2...) i was able to get the same answer but the question says not to use a calculator and using those formulas of course I am going to have to use a calculator to figure out some of the roots and what not.
I haven't had to do this stuff for quite sometime now I am a ways past precalc but i was trying to help a friend and I am not sure how to do this without a calculator or a root table and any other aids other than my mind. So being that this is precalc i would assume there is a easy way do do this beyond what I am trying if the teacher expects it to be done without a calc so if you know how please enlighten me.
It's actually very simple once you know how to do it. Forget about cosine for a moment. Some angle (x) equals the arcsine of -1/3 -- so x=arcsin(-1/3). So you know that the sin(x)=-1/3. Now you can make a right triangle in the IV quadrant and solve for the cosine value, since you are simply solving for the cos(arcsin(-1/3)) or cos(x).
You can also try to work out the general formula for cos(arcsin(x)). Here we go.
Let [tex]\alpha = \arcsin(x) \Rightarrow \sin \alpha = x[/tex]
cos(arcsin(x)) will become: [tex]\cos \alpha[/tex]
Also, you should note that arcsin(x) will return the values in the interval [tex]\left[ - \frac{\pi}{2} ; \ \frac{\pi}{2}\right][/tex], i.e [tex]\alpha[/tex] is in I, and IV quadrant, and its cosine value should be positive. So we have:
[tex]\cos \alpha = \sqrt{1 - \sin ^ 2 \alpha} = \sqrt{1 - x ^ 2}[/tex]
Applying the formula to your question yielding:
[tex]\cos \left( \arcsin \left( - \frac{1}{3} \right) \right)) = \sqrt{1 - \left( -\frac{1}{3} \right) ^ 2} = \sqrt{1 - \frac{1}{9}} = \frac{2\sqrt{2}}{3}[/tex]. :)
You can do the same and find the general formula to:
sin(arccos(x))
Can you get it? :)
sin(arccos(x))
Can you get it? :)
thanks for both of you for the replies. I especially apreciate yours VietDao29, that way seems to be the best route in finding the aswer via no calculator because of its simplicity, i know with the triangle method although easy not so much without the calculator.
Yeah I think his method is better too. :biggrin:
  • · Replies 17 ·
10K
  • · Replies 33 ·
  • · Replies 25 ·
