Difficult Derivation Excercise
  • Thread starter Thread starter alba_ei
    Derivation
The discussion revolves around a problem involving the intersection of a circle and an ellipse, specifically focusing on finding the radius of the circle that intersects the ellipse at right angles. The equations provided include the standard forms for both the circle and the ellipse.
  • Participants discuss the derivatives of the circle and ellipse and their relationship at the intersection points. There are attempts to derive the intersection points and set the derivatives equal to establish conditions for right angles. Some participants express confusion over the correctness of their derived expressions and the discrepancies with the expected answer.
Several participants are actively exploring different methods to find the intersection points and the corresponding radius. Some have provided alternative approaches to equating the derivatives, while others are questioning the assumptions made in their calculations. The discussion is ongoing, with no clear consensus on the correct method or solution yet.
Participants note potential errors in their calculations and express uncertainty about the conditions under which the circle intersects the ellipse. There is mention of the graphical interpretation of the problem, particularly regarding the number of intersection points based on the radius of the circle.
alba_ei
Consider a circle with centre (2a, 0) with radius such that cuts in right angle to the ellipse [tex]b^2 x^2 + a^2 y^2 = a^2 b^2[/tex]. Find the radius
[tex](x-2a)^2 + y^2 = r^2[/tex]
Answer: [tex]r^2 = \frac{3}{4} (3a^2 + b^2)[/tex]
First obtain the derivates:
[tex]y' = -\frac{b^2 x}{a^2 x}[/tex]
[tex]y' = \frac{2a-x}{y}[/tex]
equal the derivates to -1 and 1 to obtain right angle
[tex]b^2 x = a^2 y[/tex]
[tex]y = 2a-x[/tex]
Now theyre perpendicular. Then solve for x and y, to obtain intersection points:
[tex]y = \frac{2ab}{a^2+b^2}[/tex]
[tex]x = \frac{2a^3}{a^2+b^2}[/tex]
In the following step i think i made a mistake but i don't know which or why. I substituted the x and y values in the circle equation, the answer isn't right.
[tex]r^2 = (\frac{2a^3}{a^2+b^2} - 2a)^2 +(\frac{2ab}{a^2+b^2})^2[/tex]
[tex]r^2 = \frac{4a^2 b^4 + 4a^2 + b^2}{(a^2+b^2)^2}[/tex]
:confused:
Could you help me? Thankyou
Ok first off, if two curves intersect at right angles, then the derivative of one is going to be equal to the negative reciprocal of the other. So if f(x) and g(x) intersect at point a, they interstect at right angles if f'(a)=-1/g'(a). So like if f'(a) is 2, then g'(a) would be -1/2, etc. etc.
Second, of the two relavant equations you listed, on is an ellipse and the other is a circle with center outside the ellipse. Graphically, you know that the circle intersect the ellipse at either zero, one, or two points. In the case of one point, the intersection is tangental, so that's not what you want. Also, graphically, you should be able to see that the case of two point can only exist for values of r such that r > a.
So given that, first solve those two equations for the two points (x,y), each in terms of r, where they intersect. Graphically, you should be able to see both points will have the same value of x and the values of y will be plus and minus something. So solve that, giving you the intersection points x and y in terms of r.
Then determine the derivatives of each of the curves at that point, also in terms of r. Then, in order to get the value r that you are looking for, set the derivative of one equal to the negative reciprocal of the other, and solve for r.
Okay in this attempt of solution first i obtain the derivate of circle and ellipse.
Circle:
Ellipse
Derivate of circle
Derivate of ellipse
[tex]y' = -\frac{b^2 x}{a^2 y}[/tex]
After i equal the derivate of circle to 1 and the derivate of the ellipse to -1 i solve for y and x to find the intersection point.
[tex]\frac{2a-x}{y} = 1[/tex]
[tex]-\frac{b^2 x}{a^2 y} = -1[/tex]
[tex]y = \frac{2ab^2}{a^2+b^2}[/tex]
so then substituted the value of x and y in the circle equation
[tex]r^2 = (\frac{2a^3}{a^2+b^2} - 2a)^2 +(\frac{2ab^2}{a^2+b^2})^2[/tex]
[tex]r^2 = \frac{8a^2 b^4}{(a^2+b^2)^2}[/tex]
But after all that work I am surprised that the answer doesn't match to the one from the book that is
That ansewr even contain fractions and is totally different from mine. I've tried this problem several times but the ansewer still the same, where is my eeror.
no, when you have the derivatives of the circle and the ellipse, you don't assign 1 and -1 to them. Just multiply them. what you'll get is something like: Ax^2+Bx+Cy^2=0, now solve this quadric equation for x in terms of y, and plug them back into the equations.
