Can someone confirm this U sub is legal?
  • Thread starter Thread starter Saladsamurai
The discussion revolves around the legality of a substitution method in the integration of the function e^{-4x}. Participants are examining the steps involved in the integration process and the validity of the proposed substitution.
  • Participants are discussing the initial substitution of u = e^x and its implications. Some question the correctness of the first line of the integration, suggesting alternative substitutions such as u = -4x. There are also mentions of checking the final answer by taking the derivative.
The discussion is active, with multiple participants providing feedback on the original poster's approach. There are differing opinions on the best substitution method, and while some corrections are noted, no consensus has been reached regarding the most effective approach.
Some participants highlight potential mistakes in the original setup and suggest that the integration process may be simplified with different substitutions. There is an emphasis on ensuring accuracy in the steps taken during integration.
Saladsamurai
[tex]\int e^{-4x} dx\\ = \int e^x *e^{-3x}[/tex] let u=e^x so du=e^x dx
so [tex]\int u^{-3} du[/tex]
=[tex]-\frac{1}{2}e^{-2x}+c[/tex]
Thanks,
Casey
You made a mistake in the first line, however, it is easy to fix the resulting steps. It should be [itex]e^x \times e^{-5x}[/itex]. I think your method works, however, I think the substitution [itex]u = -4x[/itex] is much easier.
Also, remember that you can check to see if your answer is correct by taking the derivative at the end.
[tex]\int e^{-4x} dx\\ = \int e^{-x} *e^{-3x}[/tex]
you forgot the negative sign on [tex]e^x[/tex].
But as mattmns above me suggested, just use u = -4x
Oh yeah..it's not a power to a power.
I did it both ways, and yes they are equal,...and u=-4x is easier.
[tex]-\frac{1}{4}e^{-4x}[/tex]
Thanks,
Casey
  • · Replies 22 ·
