Heat equilibrium between two different rods
  • Thread starter Thread starter Ojizo88
    Equilibrium Heat
The problem involves a heat equilibrium scenario between two different rods made of aluminum and brass, with specified lengths and temperatures at their ends. The goal is to determine the temperature at the junction of the two materials in a steady state, where no heat is lost through the sides of the rod.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the relationship between heat flow and temperature in steady state, questioning the original poster's understanding of heat flow dynamics. There are attempts to verify the algebraic setup of the heat transfer equations and concerns about arithmetic errors leading to an incorrect temperature result.
Some participants have provided guidance on rechecking calculations and have confirmed the algebraic approach as correct. There is ongoing exploration of the assumptions made regarding heat flow in steady state, with clarification sought on the implications of temperature changes along the rods.
Participants note the importance of careful arithmetic in calculations and the need to clarify the definition of steady state in the context of heat transfer. The original poster expresses uncertainty about their approach and seeks further assistance to resolve their confusion.
Ojizo88
[SOLVED] Heat equilibrium between two different rods
A rod 1.3 m long consists of a 0.8 m length of Aluminium joined end-to-end to a 0.5 m length of brass. The free end of the aluminium section is maintained at 150 oC and the free end of the brass piece is maintained at 20 oC. No heat is lost through the sides of the rod. In the steady state, what is the temperature of the point where the two metals are joined ? (Thermal conductivity of brass k_b = 109 W/mK and Thermal conductivity of Aluminum k_a = 237 W/mK).
[tex]H=-kA[/tex] [tex]\frac{\Delta T}{\Delta x}[/tex]
Well, you know in steady state that there is no net heat flow so H_aluminum = H_brass. So you have...(I give up for tying to figure this formatting out for now so please forgive me)
[tex](-k_{a} A (T_{h} - T_{e})) / l_{a} = (-k_{b} A (T_{e} - T_{c})) / l_{b}[/tex] , with [tex]T_{e}[/tex] being the point in the middle and [tex]T_{h}[/tex] and [tex]T_{c}[/tex] being the hold and cold ends respectively.
Since the cross sectional area of the two are the same, those will cancel and youre left with...
[tex](-k_{a} T_{h} + k_{a} T_{e}) / l_{a} = (-k_{b} T_{e} + k_{b} T_{c}) / l_{b}[/tex]
solving for [tex]T_{e}[/tex] you get...
[tex]k_{a} T_{h} l_{b} + k_{b} T_{c} l_{a} = k_{b} T_{e} l_{a} + k_{a} T_{e} l_{b}[/tex]
Which then goes to...
[tex]T_{e} = (k_{a} T_{h} l_{b} + k_{b} T_{c} l_{a}) / (k_{b} l_{a} + k_{a} l_{b})[/tex]
However, when I put in the values I have, I get an answer HIGHER than the original [tex]T_{h}[/tex]!
I don't get what I am doing wrong here.
I have a problem after this where I have to solve for [tex]T_{e}[/tex] when 3 rods come together but I clearly can't do that one properly if I can't solve this one first!
Little bump before bed. Maybe someone can figure out what I am doing incorrectly :(
You are doing incorrect arithmetics, that's all. Recheck you calc. The ans should be 95 C.
Well is the algebra at least correct? Because I've gone over that time and time again and can't find anything wrong. Maybe I am losing the forest in the threes though...
The algebra is correct. Do the arithmetic very carefully once.
I forgot to mention this. You had written "Well, you know in steady state that there is no net heat flow..." That is not correct. In a steady state, heat does flow, but the temp at every point remains constant.
There is one thing I want to add here:
Your first equation is wrong in terms of + and -.
When your x goes up, your T will drop. This means you should say:
-ka.A.(-(Th-Te))/la = - kb.A.(-(Te-Tc))/lb
Firstly, thank you for the assistance. I found out where the wrong step was. I figured it was something I was doing wrong algebraically.
Secondly, I am sorry if I worded my statement improperly. I was trying to imply the fact that at the middle point, there is no NET heat flow that will cause a temperature change. It has come to equilibrium. I apologize for any confusion this may have caused.
9K
  • · Replies 21 ·
