How Do You Determine the Source Location of a Sound Wave?
The discussion revolves around determining the location of a sound source based on the simultaneous arrival of sound waves at two listeners positioned along the x-axis. The problem includes calculating the x-coordinate of the source and the y-coordinate of a third listener located on the positive y-axis.
  • Participants explore the concept of wave fronts and their relationship to listener positions, with some suggesting the use of midpoints to find the source location. Questions arise regarding the assumptions of equal distances from the source and the implications of the wave's propagation in different dimensions.
Participants are actively engaging with the problem, questioning the assumptions made about distances and the nature of the wave front. Some guidance has been offered regarding the interpretation of distances and the relevance of the wave's properties, but no consensus has been reached on the approach to finding the solution.
There is uncertainty regarding the wavelength and the phase change, which some participants note as constraints in their reasoning. The problem's setup suggests a one-dimensional interpretation, yet the inclusion of a listener on the y-axis introduces complexity that is being debated.
Grapz
A sound source is located somewhere along the x-axis. Experiments show that the same wave front simultaneously reaches listeners at x = -7.0 m and x = 3 m
a) What is the x-coordinate of the source?
b) A third listener is positioned along the positive y-axis. What is her y-coordinate if the same wave front reaches her at the same instant it does the first two listeners?
Change in phase = 2pi ( change in x) / lamda
For a, since its the same wave front, i just took the mid point. I'm not sure if this is correct.
For b. I know that if i can find the wavelength. I can find the velocity of the wave and since the time is the same i can use it to find the distance.
But the problem is, i don't know how to find the wavelength.
The above equation change in phase = 2pi ( change in x ) / lamda
This equation gives me troubles. I don't have the change in phase, and i don't know lamda. SO how do i solve this? Also i don't know if the change in x is -7 - 3 = -10 or 3 - 7 = -4
Please help
Nope, my textbook does a much better job than wikipedia, thanks tho
i dun get it
I'm assuming the source sends out a spherical wave, but you only have to the circular portion as it expands from the source form a bird's eye view. This means you must fit the two points to a circle.
NOTE: reviewing your problem, it's 1d, not 2d, so you're solution is likely correct. It's similar to if you measured opposing points on that circular radius, ignoring the 2nd dimension of the circle.
the velocity of sound waves is a constant through an atmosphere of uniform temperature (which you can also assume since you're in the bird's-eye view, ignoring vertical components). Maybe you're allowed to use that constant.
Hi Grapz,
You don't need the wavelength; you can already find the distance. The problem says the two people on the x-axis receive the same wavefront at the same time. When you used the midpoint to answer part a, what were you assuming about their distances from the speaker?
If the person on the y-axis has to receive the same wavefront, how far does he have to be from the speaker?
you are assuming that the people are equal distance away from the source right? so that's 5 metres from the source.. so why isn't the distance on the y-axis also 5 metres?
because the third person is on the y-axis...so his/her x coordinate is 0...since this person is not directly above the sound source he/she is not 5 meters away
  • · Replies 29 ·
