Q=mcT heat problem, were did i go wrong?
  • Thread starter Thread starter Senjai
    Heat
The discussion revolves around a heat transfer problem involving a sample of aluminum and the application of the formula Q = mcΔT to determine the final temperature after adding a specific amount of heat. The subject area is thermodynamics, specifically focusing on heat transfer and specific heat capacity.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to apply the heat transfer equation but questions their rearrangement of the formula. Some participants suggest a different arrangement for calculating the final temperature.
Participants are actively discussing the rearrangement of the heat transfer equation. There is an indication that a potentially correct approach has been suggested, but no explicit consensus has been reached regarding the final calculation.
The original poster expresses confusion over their calculated final temperature and references a target temperature, indicating a potential misunderstanding in the application of the formula. There is also a mention of specific heat capacity values and units that may be relevant to the discussion.
Senjai
[SOLVED] Q=mcT heat problem, were did i go wrong?
If a 45g sample of aluminum at 22 degrees C is given 6.0 x 10^3 J of heat, what will its final temperature be?
[tex]Q = mc \Delta T[/tex]
i found in my textbook that aluminum has a specific heat capacity of 900
so c = 900.
[tex]Q = mc( T' - T )[/tex]
[tex]T' - T = \frac{Q}{mc}[/tex]
[tex]T' = \frac{Q + T}{mc}[/tex]
[tex]T' = \frac{(6.0 x 10^3 J) + 22\deg}{(0.045kg)(900)}[/tex]
i got 148 Deg C which is wrong... i need 170 Deg C
You've just rearranged wrongly. Its not (Q+T)/mc.
so is it [tex]T' = \frac{Q}{mc} + T[/tex] ??
That should work.
kurdt ,
what would the worked out solution look like for the last step?
  • · Replies 21 ·
