Conductivity Tensor: Problem 4.7 Purcell Analysis
The forum discussion focuses on Problem 4.7 from Purcell regarding the conductivity tensor of a composite conductor made of alternating plates of tin and silver. The user derived the perpendicular conductivity, \(\sigma_{\perp}\), as \(\frac{2 \sigma_1 \sigma_2}{\sigma_1 + \sigma_2}\) and the parallel conductivity, \(\sigma_{\parallel}\), as \(\frac{\sigma_1 + 2\sigma_2}{3}\). The user calculated the ratio \(\sigma_{\perp} / \sigma_{\parallel}\) and found a discrepancy with the book's answer, leading to a correction suggestion that \(\sigma_{\perp}\) should be \(\frac{3 \sigma_{Ag} \sigma_{Sn}}{\sigma_{Sn} + 2 \sigma_{Ag}}\).
  • Understanding of conductivity tensors and their applications in composite materials.
  • Familiarity with Ohm's Law in its microscopic form: \(\mathbf{J} = \sigma \mathbf{E}\).
  • Knowledge of current density and electric field relationships in conductive materials.
  • Basic concepts of ratio calculations and algebraic manipulation in physics.
  • Review the derivation of conductivity tensors in composite materials.
  • Study the implications of charge layers at material interfaces in conductive systems.
  • Explore the differences between parallel and perpendicular conductivity in layered conductors.
  • Investigate the physical significance of the ratio \(\sigma_{\perp} / \sigma_{\parallel}\) in material science.
Students and professionals in physics, materials science, and electrical engineering who are studying the behavior of composite conductors and their conductivity properties.
psholtz
I'm working through Problem 4.7 in Purcell, on conductivity tensors.
We build a conductor by alternately stacking plates of tin and silver (differing conductivities). When we pass a current through this "composite" conductor, we will get a different value for the conductivity depending on whether we apply the current (a) parallel; or (b) perpendicular to the plates.
Let [tex]\sigma_1[/tex] designate the conductivity of the silver plate, and [tex]\sigma_2[/tex] designate the conductivity of the tin.
The silver plate is 100 angstrom thick, and the tin plate is 200 angstrom thick.
We are seeking the "ratio" of [tex]\sigma_{\perp} / \sigma_{\parallel}[/tex]
The important equation is the "microscopic" version of Ohm's Law:
[tex]\mathbf{J} = \sigma \mathbf{E}[/tex]
First let's derive a value for [tex]\sigma_{\perp}[/tex], which is to say, the conductivity we get when passing the current perpendicular to the plates. The current density must be the same in both regions (silver and tin). Because the conductivities of the metals differ, we must have a charge layer that builds up at the junction between the metal plates. In other words:
[tex]J_1 = J_2[/tex]
[tex]\sigma_1 E_1 = \sigma_2 E_2[/tex]
and since [tex]\sigma_1 > \sigma_2[/tex], we must have [tex]E_1 < E_2[/tex].
Let [tex]E_0[/tex] be the 'net" electric field driving the (uniform) current density in both regions (i.e., [tex]J_{net} = \sigma_{net} E_0 = \sigma_{\perp} E_0[/tex]). We have:
[tex]E_1 = E_0 - E_{charge layer}[/tex]
[tex]E_2 = E_0 + E_{charge layer}[/tex]
from which we obtain:
[tex]\large{ E_0 = \frac{1}{2}(E_1 + E_2)}[/tex]
[tex]\large{E_0 = \frac{J}{2}(\frac{1}{\sigma_1} + \frac{1}{\sigma_2})}[/tex]
[tex]\large{E_0 = \frac{J}{2}( \frac{\sigma_1 + \sigma_2}{\sigma_1 \sigma_2} )}[/tex]
[tex]\large{J = \frac{2 \sigma_1 \sigma_2}{\sigma_1 + \sigma_2} E_0 }[/tex]
From which we conclude:
[tex]\sigma_{\perp} = \frac{2 \sigma_1 \sigma_2}{\sigma_1 + \sigma_2}[/tex]
Note that if [tex]\sigma_1 = \sigma_2 = \sigma[/tex], we have:
[tex]\sigma_{\perp} = \frac{2 \sigma^2}{2 \sigma} = \sigma[/tex]
which is the result we expect.
Now let's derive the "parallel" conductivity. Again, we will have a net "applied" electric field [tex]E_0[/tex] but this time, the applied field will produce two distinct current denstities in the respective metal layers. The "net" current density, the one we will use to calculate the "parallel" conductivity of the material, will be the vector sum of these two (in other words, there will be no net charge layer). We have:
[tex]J_1 = \sigma_1 E_0[/tex]
[tex]J_2 = \sigma_2 E_0[/tex]
Bearing in mind that the silver layer (sigma 1) is 100 ang thick, and the tin layer (sigma 2) is 200 ang thick, we have:
[tex]J_{total} = J_1 + J_2 = \frac{\sigma_1 + 2\sigma_2}{3} E_0[/tex]
So that:
[tex]\sigma_{\parallel} = \frac{\sigma_1 + 2\sigma_2}{3}[/tex]
Again, if [tex]\sigma_1 = \sigma_2 = \sigma[/tex], we have:
[tex]\sigma_{\parallel} = \frac{\sigma + 2\sigma}{3} = \sigma[/tex]
which is the expected result.
The ratio we initially set out to calculate is thus:
[tex]\sigma_{\perp} / \sigma_{\parallel} = \frac{6 \sigma_1 \sigma_2}{(\sigma_1 + \sigma_2)(\sigma_1 + 2\sigma_2)}[/tex]
If we suppose that [tex]\sigma_1 = k\sigma_2[/tex] this reduces to:
[tex]\sigma_{\perp} / \sigma_{\parallel} = \frac{6 k \sigma_2^2}{(k\sigma_2 + \sigma_2)(k\sigma_2 + 2\sigma_2)} = \frac{6 k \sigma_2^2}{(k + 1)(k + 2)\sigma_2^2}[/tex]
[tex]\sigma_{\perp} / \sigma_{\parallel} = \frac{6k}{(k+1)(k+2)}[/tex]
Taking k=7.2, we have:
[tex]\sigma_{\perp} / \sigma_{\parallel} = 0.573[/tex]
However, the answer in the book is 0.457.
What am I doing wrong?
Your $\sigma_\perp$ equation is wrong. It should be $\sigma_\perp = \frac{3 \sigma_Ag \sigma_sn}{\sigma_Sn + 2 \sigma_Ag}$.
  • · Replies 17 ·
