Understanding the Beer-Lambert Law: Questions on Absorbance and Concentration
  • Context: Undergrad
  • Thread starter Thread starter NLO
    Law
The discussion centers on the Beer-Lambert Law, specifically the calculation of absorbance (A) using the formula A = alpha * l * c, where alpha is derived from the extinction coefficient (k) and wavelength (lambda). The extinction coefficient k is confirmed to be specific to the absorbing material, and concentration (c) can be expressed dimensionlessly, such as 0.01 for 1 percent mass. The correct application of these parameters allows for accurate modeling of light attenuation in materials.
  • Understanding of the Beer-Lambert Law
  • Knowledge of extinction coefficients in optics
  • Familiarity with light attenuation concepts
  • Basic mathematical skills for applying exponential functions
  • Research the calculation of extinction coefficients for various materials
  • Explore the implications of wavelength on absorbance in different mediums
  • Learn about the practical applications of the Beer-Lambert Law in spectroscopy
  • Investigate methods for measuring concentration in parts per million (ppm)
Researchers, students, and professionals in fields such as chemistry, physics, and materials science who are involved in light absorption studies and spectroscopic analysis will benefit from this discussion.
NLO
Hi!
I am looking for help with understanding how to specify correct absorbance values for my little study project of modeling attenuation of light in a material.
Here are the sources that I am using:
1) The Wikipedia article
http://en.wikipedia.org/wiki/Beer-Lambert_law
states that the absorbance of a sample A is alpha*l*c, where alpha = (4*pi*k) /lambda and k is the extinction coefficient.
Question 1: Is k supposed to be the extinction coefficient of the absorbing species?
Question 2: If I am using k to calculate alpha as in the formula above, this makes c to be dimensionless (right?). How shall I then understand c?
I found here:
http://www.ilpi.com/msds/ref/concentration.html
that concentration can be specified as percent by mass or parts per million. Is this the case? Shall the concentration in my case be specified as dimensionless? For example 0.01 for 1 percent of mass of the absorbing species in the material?
Thank you for your help!
k is the extinction coefficient for the material and the concentration c is dimensionless in parts per million. Plug them into your equation and you should be ok.
Dr Transport, thanks!
Did I get it right that k is meant to be here the extinction coefficient of the material not of the absorbing particles?
So if i have k=0.07 for light with wavelength = 400 nm, then I get the following expression for attenuated light:
I1 = I0* exp(-path_length * 0.01 * (4*pi*0.07)/(400 * 1e-9)),
where:
1) path_length - length of path of light in material (measured in meters)
2) 0.01 - concentration of absorbing particles (equal to 1 percent of mass)
3) (4 * pi * 0.07)/(400 * 1e-9) - the absorption coefficient alpha (with wavelength measured in meters as well)
Is this correct?
