Path from Business to Engineering?
The discussion revolves around the potential pathways for individuals with a business degree to transition into engineering or science fields through master's level programs. Participants explore the feasibility of such transitions, the necessary prerequisites, and existing educational programs that may facilitate this shift.
  • Some participants suggest that transitioning from a business degree to a master's in engineering or science is challenging due to the foundational knowledge required in mathematics and technical subjects.
  • Others argue that while engineering may require more depth of knowledge, it is not solely about intelligence, and individuals with business degrees could potentially succeed in engineering with the right preparation.
  • A participant mentions that certain programs, like those at NC State, may allow business graduates to pursue a master's in Computer Science, provided they complete necessary bridge courses.
  • Concerns are raised about the adequacy of a business background for meeting the prerequisites of engineering programs, with some stating that significant catch-up work would be necessary.
  • There is mention of programs like "Business Science" or "Engineering Management" that may blend business and technical education, though the specifics of these programs are questioned.
  • Some participants highlight the differences in core curriculum requirements between business and engineering degrees, emphasizing the need for foundational courses in engineering that business majors typically do not take.
Participants express differing views on the feasibility of transitioning from business to engineering, with some asserting it is difficult due to prerequisite knowledge, while others believe it is possible with adequate preparation. No consensus is reached on the viability of such educational pathways.
Participants note that the transition may require completing multiple undergraduate courses to meet the prerequisites for master's programs in engineering or science, which could vary significantly depending on the specific field of study.
Individuals considering a career shift from business to engineering or science, educators in higher education, and academic advisors may find this discussion relevant.
sanman
Hi,
I'm asking on behalf of a friend.
We all know that a person with a Bachelor's degree in engineering/applied-science can apply for an MBA program, to then take their engineering base onto a business-oriented path. There are many technical managers who have come through this route, or managers in science-based companies.
But what about doing the opposite -- starting off with a business degree (bachelor's) and taking some master's level program that will take your business base towards a more science/engineering-oriented path.
Are there any known programs that will do this? They would have to be post-bachelor's programs, imho. Fair is fair after all -- if the B.Sc can get an MBA, then why can't the B.Com get a Master's in science/engineering?
Comments, please?
I know this will come of as elitist, but in engineering there is more to know that must be built on previous knowledge than in liberal arts. So while it is possible for an engineering student to take many mid to upper level busineess, poly sci, etc., courses and do fine, the reverse is not true. Engineering degrees typically also require more majors courses and more total courses than liberal arts degrees. The easist example is that some liberal arts majors don't take much, if any, calculus, but I'd say at least half of engineering courses require at least a 3-semester knowledge of it. You can't even take most sophomore introductory courses without it.
I would think it would be possible to go back for a second bachelor's degree and the school may knock most of the free electives and core college courses off, but that would only reduce the load by a year, maybe a year and a half.
This is the reason that it is more common for people to go the other way - get the technical degree first, then go for the MBA.
Heh, that's what I told my friend - engineering/science is harder to do than business, and so that's why the former can migrate into the latter, but not the other way. But then I thought, who's to say that each and every person who graduates from business isn't bright enough to become an engineer/scientist?
If there were such an educational option, then many who have generic business degrees could adapt themselves to the changing technological environment. Because really, the principles of business are largely timeless and unchanging, while it's the science and technology which tend to change more over time. Therefore it would be more worthwhile for the economy to give businesspeople re-training/upgrades in science and technology, than to give science and technology people re-training/upgrades in the less changing world of business.
Just some thoughts. Comments?
It isn't about intelligence, it is about knowledge and they are just different types and depths. You might say business is wider, but engineering is deeper. And I wouldn't say that any given business major couldn't be an engineer - they just chose a different path.
sanman said:
Hi,
Comments, please?
What kind of engineering? If your friend is interested in Computer Science, then he could obtain an Masters in Computer Science with an undergraduate degree in Business or whatever by taking bridge courses. NC State offers this degree. Of course the bridge courses, depending on your undergraduate degree, may be lengthy as you can imagine.
Take a look here for more information plus the pre-req's (bridge courses).
http://www.csc.ncsu.edu/academics/graduate/degrees/mcsdl.php
CS
sanman said:
Hi,
Comments, please?
It is even hard for someone with, say a Mechanical Engineering BS, to do a graduate program in Physics and vice-versa. The problem is the core courses that have a built-in sequence. Your friend could take one of the practice EIT exams or a practice subject GRE to see how well he does.
A person with a business degree would be totally, completely unprepared for a masters' program in engineering. You're missing something like five or six math classes, circuit analysis, computer programming, etc.
Some less prestigious graduate programs may still accept you, but you'll have to go take 8-10 undergraduate classes to catch up.
- Warren
Well, I heard from friends way back that the University of Waterloo, where I took chemical engineering, had later introduced bachelor's programs like "Business Science", which teaches both the business and science curricula together. Back when I took Chem Eng, the UW prided itself on its co-op work experience program giving its students an edge. But now everybody has co-op, including community colleges, so UW altered their programs to keep ahead of the competition.
I'd be interested in hearing about other institutions which offer similar programs as "Business Science".
Business Science? I wonder if that is the same thing as programs I have seen titled Engineering Management?
There really is going to be no way around the needed pre-reqs. Does a business major even know what a statics class is or covers? There would be some serious catch up work to do.
I had a statistics class when I got my first degree (business admin). However, it wasn't quite the same as the one I had to take when I received my engineering degree later in life.
Additionally, if you look at the core classes required for an engineering degree, other than those a lot of the courses you take in a liberal arts program cross over (English, literature, arts, philosophy, foreign language, etc). So by taking the missing core course, although quite a few (around 10 probably), it is not as impossible as one might think.
CS
He didn't say statistics, he said statics. Business majors would never normally study such things.
- Warren
- Warren
Opps! I skimmed over that too fast! Sorry!
CS
Engineering Management (as offered at the University of Arizona), while not a "real" engineering degree in my opinion, might give a business student a view into the engineering world without the need of too many catch-up courses.
EM is basically a major that splits classes between engineering and business, with some basic pre-reqs in each. I'm not sure I see it as a very useful primary major to have, but as a second major it could be somewhat useful.
I have minor in Engineering Management, it's useful if you want your career path to tend toward management instead of actual engineering work. It makes you upwardly mobile so to speak.
CS
[edit: sounds like different schools use the same names differently for these majors. That's actually a concern I have about Drexel's "Engineering Management" degree - it appears to me to be an MBA for engineers, but can I sell it that way to prospective employers or am I better off with an actual MBA?]
No. "Engineering Management" is far more a business degree than "Business science" is a science degree. As I understand it, it is essentially an MBA targeted at engineers. And it's a graduate degree - you have to be an engineer first. http://www.coeonline.drexel.edu/egmt/index.php
But maybe you're thinking of degrees like "Business and engineering" degree, which is under the college of business: http://www.lebow.drexel.edu/Prospects/Undergraduate/Programs/Engineering.php
I posted links to Drexel because I went there. Drexel is on the quarter system, but the math courses (5) represent 3.5 typical semesters, so it is pretty good there, but there are only 6 (equivalent of 4 semester courses) actual engineering courses. Basically, it's just about a sophomore level engineering education - you wouldn't have even picked a major yet in a normal engineering discipline.
From what I've seen/heard, "business and engineering" is mostly just a good way for those who wash-out of engineering to not fall behind the curve for graduation.
Contrast that with the "engineering managment" curriculum, which is essentially all business, just with all the examples and case studies being from engineering companies: http://www.coe-online.drexel.edu/egmt/Courses.php
Even for someone with the requisite math skills (my sister, for example, double-majored in Business and Math), that still doesn't get you through your sophomore year as an engineer. There are just too many total courses and courses-on-top-of-courses that need to be taken in series.
He said STATICS, for the love of God, not STATISTICS.
- Warren
- Warren
Saw it right after I posted it and fixed it... :redface:
Thanks Warren. I can stop beating my head on the keyboard.
