[SOLVED] Giant Swing, Uniform Circular Motion
by clope023
Tags: circular, giant, motion, solved, swing, uniform
clope023
clope023 is offline
#1
Feb12-08, 10:55 AM
P: 593
The "Giant Swing" at a county fair consists of a vertical central shaft with a number of horizontal arms attached at its upper end. Each arm supports a seat suspended from a cable 5.00 long, the upper end of the cable being fastened to the arm at a point 3.00 from the central shaft.
A) Find the time of one revolution of the swing if the cable supporting a seat makes an angle of with the vertical.
B) Does the angle depend on the weight of the passenger for a given rate of revolution?
2. Relevant equations
R = Lsin(\theta)
v = [tex]\sqrt{gtan(\theta)R}[/tex]
T = 2[tex]\Pi[/tex]R/v
3. The attempt at a solution
tried using L = 3+5m*sin([tex]\theta[/tex])) to get 4m
R then equals = 2m
v then equals = [tex]\sqrt{9.8*2*tan\theta}[/tex] = 11.3m/s
T then equals 2[tex]\Pi[/tex](2m)/11.3m/s = 1.1s wrong
I tried a few other combinations where I used 3+(5sintheta) as the L and got T=4.4s which was wrong as well.
I'm not sure what I'm doing wrong, I think I have the correct equations and I know I have the right angle and distances, I guess I'm just not sure how to derive the right length and and radius.
I'm also thinking that for part B the weight will determine the angle that the seat swings, but I don't want to risk losing the only chance I have on that part of the problem (masteringphysics).
any and all help is greatly appreciated.
Phys.Org News Partner Science news on Phys.org
Going nuts? Turkey looks to pistachios to heat new eco-city
Space-tested fluid flow concept advances infectious disease diagnoses
SpaceX launches supplies to space station (Update)
lavalamp
lavalamp is offline
#2
Feb12-08, 11:55 AM
lavalamp's Avatar
P: 280
You might want to go back and look at this bit again:
Quote Quote by clope023 View Post
[b]L = 3+5m*sin([tex]\theta[/tex])) to get 4m
R then equals = 2m
sin(30) = 0.5, so 5*0.5 + 3 = 5.5m, and you don't need to divide it by 2, because that is the radius, not the diameter.
PhanthomJay
PhanthomJay is offline
#3
Feb12-08, 11:56 AM
Sci Advisor
HW Helper
PF Gold
PhanthomJay's Avatar
P: 5,963
It appears that you are confusing L with R. If L is the length of the cable, then what is R, which is the radius measured from the passenger to the central shaft? Also, if you draw a free body diagram and use Newton's laws, it will help to see whether or not the the mass comes into play. You shouldn't blindly be using a formula..
clope023
clope023 is offline
#4
Feb12-08, 12:36 PM
P: 593
Quote Quote by PhanthomJay View Post
I wrote it before, R = Lsin(30)
I was pretty sure it was the length of the cable alone (which would've been 5) I just wasn't sure where the distance of the angle of the seat from the vertical shaft (3m) played in.
if it's only length of cable alone, then R = 5(sin30) so R = 2.5m, does that seem more correct?
on the angle's dependance on the weight, I've drawn a free body diagram and it makes the sum of the forces be
(sigma)Fx = -marad + mgcos30 = 0
(sigma)Fy = T - mgsin30 = 0
so I would imagine the angle is dependant on the weight of the seat.
lavalamp
lavalamp is offline
#5
Feb12-08, 03:16 PM
lavalamp's Avatar
P: 280
As I already said:
Quote Quote by lavalamp View Post
R then equals = 2m
clope023
clope023 is offline
#6
Feb12-08, 03:51 PM
P: 593
thanks, I got the answer to the first part using that radius, I wasn't picturing in my head that the swing literally makes a circle when viewed overhead and the distance of 3m + (5sin30) was the radius of that circle.
now fro for the 2nd part, as I said I did a free body diagram and found the forces acting in each direction, but I'm actually still not certain, I believe the mass would cancel out from the 2 equations if I set them equal to each other, so the answer would be that it doesn't depend on the mass?
PhanthomJay
#7
Feb12-08, 04:04 PM
Sci Advisor
HW Helper
PF Gold
P: 5,963
Your FBD's are not correct. In the y direction, mg acts straight down, and Tcos30 acts straight up. In the x direction, only Tsin30 acts.
clope023
clope023 is offline
#8
Feb12-08, 04:57 PM
P: 593
so then in that case Tcos30 = mg
so the angle is proportional to the mass?
clope023
clope023 is offline
#9
Feb12-08, 05:36 PM
P: 593
scracth that the angle is not proportionate to the mass, thanks for the help.
nightlaei71
nightlaei71 is offline
#10
Feb28-08, 04:22 PM
P: 9
I have the same problem as well, and I don't quite understand how velocity was derived.
Register to reply
Related Discussions
Uniform Circular Motion, Rotational Motion, Torque, and Inertia General Physics 1
Uniform Circular Motion Advanced Physics Homework 23
[SOLVED] Force for uniform circular motion Introductory Physics Homework 3
[SOLVED] Uniform circular motion problems Introductory Physics Homework 4
Uniform Circular Motion Introductory Physics Homework 8
