| Thread Closed |
Artificial gravity in spinning space ship conumdrum |
Share Thread |
| Apr5-08, 09:31 PM | #1 |
In discussions, and novels, about deep space missions, we frequently read of the plan to spin the space ship to produce artificial gravity. This intuitively makes good sense.
But would it work in a ship that is very, very, very far away from any stars or other matter? That is, if the ship is spinning, relative to what is it spinning? If the proximity to matter is irrelevant, then does the universe have some inherent sense of direction or "upness"? |
| Apr6-08, 05:06 AM | #2 |
Recognitions:
As far as we know, it would work. Also, there is only so far you can be from stars and other matter. The emptiest regions we see is probably between the galactic super clusters or possibly the "voids" between the complexes made by these, the “walls”. But these "empty" spaces, too, contain dark matter. So, if you are trying to invoke Mach’s Principle, it’ll be difficult to conduct any experiment “sufficiently” removed from matter in this universe.
The relevant spinning appears to be with respect to the "distant" matter. Exactly how the distant matter influences the inertia of an object is not known. But according to the qualitative results of Mach’s Principle, nearby masses also should influence inertia locally. This type of phenomenon was investigated by Lens and Thirring in the context of GR, and is known as the rotational frame dragging effect. The effect of local masses on the mass of a test body is also predicted in GR, but the effect is too small to measure with available methods. Broadly speaking, the universe seems not to distinguish between uniform velocities but between accelerations with respect to the average distribution of matter. |
| Apr6-08, 06:46 AM | #3 |
Mach’s Principle
Ah! That is what I was looking for. Thank you. |
| Apr6-08, 10:38 AM | #4 |
| Apr6-08, 11:46 AM | #5 |
Is there even any scientific proof of this concept? If a space station is spinning rapidly around an axis in space .. simulated gravity would come from centrifugal force? I've heard lots of talk about this, but where is the proof? Does NASA have a video clip or experiment data?
| Apr6-08, 01:51 PM | #6 |
Yea there is proof; acceleration is a change in velocity. When you are spining around an axis, you are changing velocity from the centripetal force keeping you from travelling in a straight line. This force can feel just like like gravity, if you are far enough away from the center to where your height towards the center doesn't have a noticable effect on the force distribution on your body. Otherwise, I think your head would feel lighter while standing. But another thing would happen, if you threw a ball with equal velocity of the angular velocity of the ship(times the radius), but in opposite direction, it would just float above the surface as you spun around and it stood still relative to the center of mass of your ship. So, there would be strange things that made it not feel like gravity. If you wanted to toss something to your friend on the other side of the ship, you would have to throw it with a tangeant component to the ship's radius and opposite direction of your real velocity at that point, then it will reach him. So the effects would not be exactly like gravity. If you tried throwing it directly at him, you may just end up spinning around the axis and it landing in your face. Just like if you threw it straight up in gravity. If you were sitting down and stood straight up, you would probably fall over because your body's angular momentum stays the same while your center of mass moves in toward the center.
Have you ever been on one of these? http://video.google.com/videoplay?do...arch&plindex=0 Notice at the end of the video when he tries to walk towards the camera, he jerks over to his left. |
| Apr6-08, 02:30 PM | #7 |
PatPwnt, Thanks for that video, it was entertaining. But, it proves nothing really.
Please explain why: 1. This simulates the same effects that would occur in outer space. 2. Centrifugal force can't be the 'redirection' of gravity. |
| Apr6-08, 02:46 PM | #8 |
It's not redirection of gravity, it's redirection of motion which happens to behave a bit like gravity to the person being spun.
| Apr6-08, 02:48 PM | #9 |
Ok. Prove it. A video clip like the previous one (small scale) in space would be great.
| Apr6-08, 02:53 PM | #10 |
Why do you believe it would happen any differently in space than on land? The centrifuge on land is spinning fast enough (horizontally to the ground) to OVERRIDE the effects of gravity (in the vertical axis to the ground), it'd be the same in space, only easier, because there'd be nothing pulling the person downward.
To prove it to you, I'd have to launch a centrifuge into deep space, which is beyond my current budget I'm afraid. |
| Apr6-08, 03:02 PM | #11 |
| Apr6-08, 10:30 PM | #12 |
Is it safe to say centrifugal existing in outer space is just an assumption?
| Apr6-08, 10:54 PM | #13 |
| Apr6-08, 11:03 PM | #14 |
Recognitions:
![]() What more can we tell you about the existence of centrifugal force? The earth, the Sun, Jupiter, to name a few -- all these bodies which are in "space" -- bulge out at the equator due to centrifugal force. The bulges are visible. These are your large scale experiments in space. Please don't hijack this thread. If you have so much doubt, start a new one. ------------------------------------------------------------- Dear Mentor/Admin, Doesn't nuby's previous post violate the PF rules/guidelines? Someone may as well question Newton's laws of motion directly, instead of indirectly as member nuby is doing. |
| Apr6-08, 11:27 PM | #15 |
| Apr7-08, 05:06 AM | #16 |
rotational velocity is absolute. it's not spinning if the folks in the outer rim of the cylinderical spaceship are experiencing 0g. This sounds like Newton's bucket argument. I was pleased that someone mentioned Mach's Principle, which caused me to find the wikipedia discussion on the same. I am content to learn that Einstein grappled with the issue and decided that inertia originates in a kind of interaction between bodies. That is, (as I understand it) the presence of other matter (I guess all matter in the universe) determines what is and is not spinning. |
| Apr7-08, 05:13 AM | #17 |
Start by Googling NASA JSC. Specifically, you might also look at work done by Scott Wood. |
| Thread Closed |
Similar discussions for: Artificial gravity in spinning space ship conumdrum
| Nasa's new and improved ANTI-MATTER space ship | Astrophysics | 38 | ||
| paticle accelerator in space ship help pls | Special & General Relativity | 7 | ||
| space ship collision | Brain Teasers | 2 | ||
| Black Sky: Space Ship One documentary on Science Channel | Aerospace Engineering | 1 | ||
