Thread Closed
[SOLVED] What is the phase difference between the motions of two points on the wave..
Share Thread Thread Tools
May11-08, 11:33 AM   #1
The frequency of a certain wave is [tex]500Hz[/tex] and its speed is [tex]340ms^{-1}[/tex].What is the phase difference between the motions of two points on the wave [tex]0.17cm[/tex] apart?
2. Relevant equations
[tex]x = \frac{d\lambda}{a}[/tex]
[tex]v = f\lambda[/tex]
3. The attempt at a solution
[tex]f = 500Hz \ \ \ v = 340ms^{-1} \ \ \ a = 0.17 \times 10^{-2} cm[/tex]
[tex]\lambda = \frac{v}{f} = \frac{340}{500} = 0.68m[/tex]
What should I do next?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
May11-08, 05:17 PM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Two points 0.68cm apart will be out of phase by 360 degrees.
May11-08, 07:10 PM   #3
Quote by Kurdt View Post
Two points [itex]\lambda[/itex] apart will be out of phase by 360 deg.
Regards,
Bill
May11-08, 07:14 PM   #4
Recognitions:
In this case that is 0.68m. Damn I just realised I said cm, but you know what I mean.
May12-08, 03:52 AM   #5
So, the answer is = 0.68m by 360° ?
May12-08, 05:02 AM   #6
Recognitions:
Homework Helper Homework Help
No, I won't be. You know the phase difference between points 0.68m apart is 360°, the question asks the phase difference for 0.17m, which happens to be a quarter the quantity of which we do know the phase difference for. Just one more step =]
May12-08, 06:16 AM   #7
Quote by looi76 View Post
Define the terms in your first relevant equation - one of those terms should be what you solve for to get the answer.
BTW - check what you wrote for "a" (cm?).
Regards,
Bill
May12-08, 06:21 AM   #8
Recognitions:
As GibZ alluded to, I was trying to coax you toward the right answer not just give you the answer outright (since that would be against forum policy).
May12-08, 06:52 AM   #9
[tex]0.68m = 360^o[/tex]
[tex]0.17m = x[/tex]
[tex]x = \frac{0.17 \times 360}{0.68}[/tex]
[tex]x = 90^o[/tex]
So, the phase difference is [tex]90^o[/tex] ?
May12-08, 06:55 AM   #10
Recognitions:
Thats correct.
Thread Closed
Thread Tools
Similar Threads for: [SOLVED] What is the phase difference between the motions of two points on the wave..
Thread Forum Replies
Phase, Phase Difference and Phase Shift General Physics 6
[SOLVED] phase difference problem - need help Introductory Physics Homework 19
[SOLVED] EM wave Phase change by reflection General Physics 0
[SOLVED] Wave equation for propogation of phase change (ice creation) insupercooled w General Physics 2
Does E field and B field has a 90 degree phase difference in EM wave Classical Physics 17
