| Thread Closed |
Booting off a usb drive on a pc that does not support it |
Share Thread | Thread Tools |
| May17-08, 08:40 AM | #1 |
I would like to boot off a usb drive on a pc that does not support it.
Has anyone thought of booting off a cd and transferring the start-up to the usb drive? |
| May17-08, 09:21 AM | #2 |
Dual boot setup perhaps.
You could also check for a BIOS update. |
| May17-08, 09:48 AM | #3 |
Recognitions:
| May17-08, 11:24 AM | #4 |
Booting off a usb drive on a pc that does not support itI forgot to say, the pc does not have a hard disk. |
| May17-08, 02:24 PM | #5 |
Recognitions:
Linux is generally easy to boot from a usb key, see puppy linux or DSL for examples.
Booting windows is tricky but can be done - see bartpe. But if your bios doesn't support booting from usb then you are SOL, it doesn't matter what is on the key if the machine isn't looking at it! Sometimes it takes a few different techniques to boot a pariculalr older PC you can make the USB key look like either a floppy, hard disc or CDROM. Any modern BIOS will boot quite happily from a USB. |
| May17-08, 03:49 PM | #6 |
| May22-08, 09:44 PM | #7 |
| May23-08, 03:35 PM | #8 |
Booting Knoppix from a USB Pendrive via Floppy |
| May23-08, 03:43 PM | #9 |
I highly recommend knoppix, its great and so easy to setup. You can run it of a cd or a usb.
| May23-08, 03:55 PM | #10 |
I like it too, the DSL that I am using is a remaster of knoppix.
In fact DSL probably makes the ideal host for vmware, because it is so small in memory and disk space requirements and can be made even smaller. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Booting off a usb drive on a pc that does not support it
| Driving a coil....Voltage drive..? Current drive..? | Electrical Engineering | 3 | ||
| Dual booting | Computing & Technology | 6 | ||
| booting cd-rom | Computing & Technology | 29 | ||
| System not booting with ati 9800 pro | Computing & Technology | 6 | ||
| Knoppix booting: invalid screen mode error | Computing & Technology | 2 | ||
