| Thread Closed |
delta potential barrier in a box |
Share Thread | Thread Tools |
| May27-08, 09:51 AM | #1 |
hi,...
i unfortunately couldn't find a solution to this problem although it seems like a classical textbook problem... how can i solve the (time independent) schroedingerequation for the following potential [tex]V(x) = \infty[/tex] for x<=-1 [tex]V(x) = a\delta(x)[/tex] for -1<x<1 [tex]V(x) = \infty[/tex] for x>=1 so at x=0 there is a barrier. i thought i can set the solutions to the left and right of x=0 for a free particle but i don't know how to handle x=0. thanks,... tommy |
| May27-08, 11:37 AM | #2 |
I haven't done this, but I think I can see how it can be done. Basically you need to define the wave function [tex]\psi(x)[/tex] in parts, for intervals -1<x<0 and 0<x<1 separately (they will be trigonometric functions), so that they vanish at the end points x=-1 and x=1, and that you get certain kind of sharp angle at the x=0. You should somehow solve how big jump there has to be in the derivative [tex]\psi'(x)[/tex] at the origin (this could be the most understanding demanding part. You can ask more questions if you don't know how to calculate with equations like [tex]D_x\theta(x)=\delta(x)[/tex] and so on). After this, substitute in some attempt of trigonometric functions with some constants, and try to figure out what set of equations you get for the constants.
| May27-08, 01:16 PM | #3 |
| May29-08, 11:05 AM | #4 |
i think the idea here is this: you have and incident wave, and reflected wave and a transmitted wave. split the problem into two parts. in region (1) (ie before the potential) the wave could be of the form q(x) = Aexp(ikx) + bexp(-ikx) (+ikx for he incident, -ikx for reflected). and in region (2) (after the potential) q(x) = Cexp(ikx) (transmitted wave).
one boundary conditon obviously is continuity of q(x), but the bc of the first derivative is found as said by Golkul43201. |
| May29-08, 12:17 PM | #5 |
It is not necessary to start with plane waves. You would then have to solve suitable superpositions to get the boundary conditions at the x=-1 and x=1 correctly. But we already know that the wave function is going to be trigonometric functions that vanish at these end points. So the attempt
[tex] \psi(x) = A\sin(B(x+1)),\quad -1<x<0 [/tex] [tex] \psi(x) = C\sin(D(x-1)),\quad 0<x<1 [/tex] gives a good start. The task that remains to be carried out, is that one must solve what constants A,B,C,D satisfy the correct boundary condition at the origin x=0. |
| May29-08, 12:26 PM | #6 |
oh yeah of course, they aren't normalizable. i completely spaced on the fact that this is in a box. obviously we need bound states... sorry to the op.
| May29-08, 12:36 PM | #7 |
Oops. I did too. Nevertheless, the procedure I outlined ought to work.
| May30-08, 11:45 AM | #8 |
thanks for your answers.
i'll outline the solution method i found for later viewers: this potential can be handled exactly the same way as the infinite square well with the exception of having 2 conditions at x=0. one to have a continuous wave function so [tex]\Psi_{left}(0)=\Psi_{right}(0)[/tex] and the other one to manage the delta potential which demands for a discontinuous first derivation of [tex]\Psi(x)[/tex] at x=0. this discontinuity condition is obtained by integrating over the schroedingerequation. thanks again and greetings. tommy |
| Thread Closed |
| Thread Tools | |
Similar Threads for: delta potential barrier in a box
| infinite potential barrier | Advanced Physics Homework | 1 | ||
| delta potential barrier | Quantum Physics | 0 | ||
| Infinite potential barrier | Quantum Physics | 8 | ||
| Barrier Potential | Advanced Physics Homework | 16 | ||
| Delta function barrier | Advanced Physics Homework | 3 | ||
