Discover How to Find Sin and Cos of Any Angle Without a Calculator
  • Thread starter Thread starter StephenDoty
    Formula Trig
The discussion revolves around finding the sine and cosine of angles that are not standard unit circle angles without the use of a calculator. Participants explore various methods and concepts related to trigonometric functions and approximations.
  • Participants suggest using double and triple angle identities, power series, and mental math tricks. There are inquiries about visualizing sine and cosine values and how to approximate these functions for small angles. Some discuss the accuracy needed for results and the use of known sine ratios for specific angles.
The discussion is active, with various approaches being proposed. Some participants provide specific methods for approximating sine and cosine values, while others question the accuracy and practicality of these methods. There is no explicit consensus, but multiple strategies are being explored.
Participants are operating under the constraint of not using calculators and are considering the accuracy of their approximations. There is a focus on small angles and the use of known trigonometric values for simplification.
StephenDoty
Is there any way to find what sin(x)= or cos(x)= when the angle is not one of the main unit circle angles without using a calculator? Like when you don't have a calculator and need to find the sin or cos of an angle.
Thank you.
Stephen
Well there's always double/triple angle identities.
You could also do a power series and add up the first few terms, I guess...
are there any mental math tricks or a way to visualize what the sin or cos of some angle equals? I mean you can't really carry around a calculator everywhere.
Any help would be appreciated.
Stephen
Hi Stephen! :smile:
For small angles, sinx = x - x³/6, and cox = 1 - x²/2 + x^4/24, are accurate enough.
For example, it gives sin30º = 0.4997 and cos30º = 0.8661.
Is that close enough? :smile:
Stephen
Double and triple identities don't require a calculator, neither does doing an infinite series if the angle is small enough...
How accurate do you wish your result to be? With basic Trig identities one can make the computation of the sin/cos of any angle into the sin/cos of an angle less than 45 degrees.
After that, either use sin or cos (30 degrees +/- x) expansions to reduce the problem to the sin/cos of an angle less than 20ish degrees, then use sin/cos (15 degrees +/- x) expansions to make the problem angle even smaller. At this point, everything else is still exact, now just approximate your small angle with the power series.
If you don't need it too exact, just a few d.p's, then Remember exact sine ratios of angles 0, 15, 30, 45, 60, 75, 90 degrees and use create a linear approximation from the one closest required angle.
  • · Replies 29 ·
  • · Replies 21 ·
