Thread Closed
measuring
Share Thread
Jul18-08, 08:23 AM   #1
measuring
i hv a question....???
plis help me!!!
a vertical container with base area measuring 14 cm by 17 cm is being filled with identical pieces of candy, each with a volume of 50 mm^3 and mass of 0.02 gr. assume that the volume of the empty spaces between the candis is negligible. if the height of the candies in the container increases at the rate of 0.250 cm/s, at what rate (kilograms per minute) does the mass of the candies in the container increases?
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Jul18-08, 10:46 AM   #2
Recognitions:
Homework Helper Homework Help
Quote by pcfighter View Post
plis help me!!!
The idea of Homework Help is to help, not do.
What have you done?
What formulas do you think apply?
How have you tried to solve it other than post it here hoping perhaps someone would do it for you?
Jul19-08, 07:04 AM   #3
yes i get already.... dm/dt=dm/dh x dh/dt
thx.. of ur help
Jul19-08, 09:23 AM   #4
Recognitions:
measuring
thx.. of ur help
How much mass can be filled into the increase in volume that the OP says will happen in one second?
You are given mass per volume. You are told the rate of change in height. Any ideas about how to figure the rate of change in volume?
Aug23-08, 05:23 PM   #5
Quote by LowlyPion View Post
I have the volume at 59.5t, so the rate of change in volume would be 59.5 cm/s. But I don't know what relation to use to relate this volume to mass? Any help would be much appreciated :)
Aug23-08, 05:48 PM   #6
Never-mind haha I related the rate of volume to the given candy density and found the rate of candy mass change! Thanks anyway :D
Aug23-08, 06:47 PM   #7
Recognitions:
Quote by ionic_scream View Post
From your original post:
"each with a volume of 50 mm^3 and mass of 0.02 gr"
I trust this was the density that you used times the increase in volume to establish your mass rate of change.
I'm glad you apparently have a handle on it.
Thread Closed
Similar discussions for: measuring
Thread Forum Replies
Measuring Mass General Physics 4
Methods of measuring G. General Physics 10
measuring the absolute value of the AU General Astronomy 1
measuring Quantum Physics 13
