Solving Trig Identity: sin5xcos3x=sin4xcos4x+sinxcosx
  • Thread starter Thread starter Geekchick
    Identity Trig
The discussion revolves around the trigonometric identity sin5xcos3x=sin4xcos4x+sinxcosx. Participants are exploring the application of trigonometric identities and formulas to verify the identity.
  • Participants discuss using the product-to-sum formulas on both sides of the equation. There is a question about the accuracy of the transformations applied to the left side, particularly regarding the resulting expressions. Some participants express uncertainty about the application of identities and the simplification process.
The discussion is active, with participants providing feedback on each other's attempts. Some guidance has been offered regarding the application of identities, and there is recognition of progress made in simplifying the left side of the equation. However, there is still exploration of the right side and its simplification.
Participants are working under the constraints of homework rules, which may limit the extent of assistance provided. There is an acknowledgment of potential missteps in applying trigonometric identities.
Geekchick
sin5xcos3x=sin4xcos4x+sinxcosx, solve the identity
all the identities and formulas mentioned in my last thread.
Alright so I thought I could use the product to sum formula on the left side which ended up being 1/2sin10x then I used the sum/difference formula on the right side and got sin5x. Now according to my calculator these are not the same, so where have I gone wrong?
Applying the product to sum formula to the left side is correct. But you don't end up with sin(10x). Where did you get that from?
alright what i did was this.
original problem sin5xcos3x=sin4xcos4x+sinxcosx
Left side sin5xcos3x
Product to sum formula sinxcosx=1/2[sin(x+y)+sin(x-y)]
plug in the numbers
1/2[sin(5x+3x)+sin(5x-3x)]
simplify
1/2(sin8x+sin2x)
simplify
1/2sin10x
right side sin4xcos4x+sinxcosx
sum/difference formula sin(x+y) = sinxcosy + cosxsiny
plug in the numbers
oh,never mind that won't work its in the form sinxcosx +sinycosy hmmm.
You're more than halfway home. You have on the left side
simplify
1/2(sin8x+sin2x)
This is fine. You can leave the left side now.
1/2(sin8x+sin2x)
simplify
1/2sin10x
Alas, angles don't add this way...
Here, don't apply the product-sum identity to the second term (well, you could, but it's overly fussy). What is sin x·cos x equal to (using another identity)? That will get you one of the pieces you're after.
Do use the product-sum identity to the first term -- now you'll be done...
Thank you so much!
  • · Replies 69 ·
12K
