Integration Involving Square Root
The discussion revolves around the integration of the expression \(\int \sqrt{t^8 + t^6} dt\), which falls under the subject area of calculus, specifically focusing on integration techniques.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants explore rewriting the integrand in different forms, such as factoring and using trigonometric or hyperbolic substitutions. There are discussions about whether to apply integration by parts or substitutions, with some participants expressing uncertainty about the next steps.
Several participants have offered different approaches, including rewriting the integral and considering various substitution methods. There is an ongoing exploration of techniques without a clear consensus on the best path forward, as participants continue to question and refine their approaches.
Some participants express confusion about the integration process and the implications of their chosen methods, indicating a need for clarification on the substitution and integration techniques involved.
cse63146
[tex]\int \sqrt{t^8 + t^6 } dt[/tex]
I'm not sure what to do next, can someone point me in the right direction? Thank you.
write t8+t6 as t6(t2+1) and then try a trig substitution.
Hi cse63146! :smile:
First thing would be to rewrite as:
[tex]\int t^3\,\sqrt{1 + t^2} dt[/tex] :wink:
EDIT: waaa! rock.freak667 beat me to it! :cry:
where [tex]t = tan\vartheta \ and \ dt =sec^2 \vartheta \ d\vartheta[/tex]?
Yes, looks ok as an approach.
stuck again (that was fast)
so I got it to this: [tex]\int tan^6 \vartheta (sec^2 \vartheta )[/tex]
do I use integration by parts here?
or would I use a second substitution with u = tan and du = sec^2 ?
I was thinking about this a bit more and I realize you don't have to do trigo substitution. You have [tex]\int t^3 \sqrt{t^2+1}dt[/tex]. Do it by parts here, multiple times.
:smile:
Nooo … it's [tex]\int tan^3 \vartheta (sec^2 \vartheta )[/tex] …
Easiest is probably to go to u straight from t (without going through θ), and then use integration by parts. :wink:
so integration by parts is the following:
[tex]\int f(x)'g(x) \ dx = f(x)g(x) - \int f(x)g'(x) \ dx[/tex]
I chose f'(x) to be [tex]\sqrt{1 + t^2}[/tex] so I could eventually get rid of t^3, but I have no idea how to find f(x)
so I need to do a trig sub like this:http://www.freemathhelp.com/forum/viewtopic.php?f=3&t=30001&start=0 but what happens to the square root? It just disappears after he uses the trig identity sin^2 + cos^2 = 1, and it's 25 instead of 5.
No … always mix-and-match to get an easy f'(x) …
in this case choose f'(x) to be [tex]t\,\sqrt{1 + t^2}[/tex] :wink:
… so I need to do a trig sub …
No … as Defennder says, you don't need a trig sub!
Either do integration by parts, staying with t, or (possibly slightly easier) just substitute v = 1 + t2, dv = … ? :smile:
The easiest method here would probably be the appropriate hyperbolic trig substitution.
dv = 2t
so would it look like this:
[tex]2\int t^2 \sqrt{v} dv[/tex]
would I write dv or dt in this case since I have both t and v.
P.S sorry it took so long to respond, I got sick shortly after this and my fever was gone this morning.
cse63146 said:
dv = 2t
Hi cse63146! I hope you feel completely better soon. :smile:
[tex]2\int t^2 \sqrt{v} dv[/tex] isn't quite finished, is it?
you can make it [tex]2\int (v - 1) \sqrt{v} dv[/tex] or just [tex]2\int (v^{3/2}\,-\,v^{1/2}) dv[/tex] :wink:
(when you make a substitution, you must change everything! :smile:)
Ah, that makes sense. Once I do the integration, I just "return" t back into the equation. Thanks.
  • · Replies 105 ·
13K
  • · Replies 26 ·
