Thread Closed
Right handed vs Left handed circular polarization
Share Thread Thread Tools
Oct1-08, 11:53 AM   #1
Hey,
I just wanted to clear up some confusion I've been having regarded which is which of these.
If I have the wave [tex] \vec{E}= E_{0X} cos(kz-\omega t)+ E_{0Y} sin(kz-\omega t) [/tex] and [tex] E_{0X}=E_{0Y} [/tex]. Then at z=0, t=0 the field is pointing completely in the x direction. Staying at z=0 ( [tex] \vec{E}= E_{0X} cos(-\omega t)+ E_{0Y} sin(-\omega t)=E_{0X}cos(\omega t)-E_{0Y}sin(\omega t) [/tex]. So that the x comp begins to decrease with time at z=0, and the y comp begins to increase negativley. Thus if the wave was coming toward you down the z-axis you'd see it rotating clockwise. If you were behind the wave you'd see it rotating counter clockwise.
This is right handed circ polarization?
Now if I have If I have the wave [tex] \vec{E}= E_{0X} cos(kz-\omega t)- E_{0Y} sin(kz-\omega t) [/tex] and [tex] E_{0X}=E_{0Y} [/tex]. Then at z=0, t=0 the field is pointing completely in the x direction again. Staying at z=0 ( [tex] \vec{E}= E_{0X} cos(-\omega t)+ E_{0Y} sin(-\omega t)=E_{0X}cos(\omega t)+E_{0Y}sin(\omega t) [/tex]. So that the x comp begins to decrease with time at z=0, and the y comp begins to increase positivley. Thus if the wave was coming toward you down the z-axis you'd see it rotating counter-clockwise. If you were behind the wave you'd see it rotating clockwise.
This is left handed circ polarization?
Does all this sound correct, and are these the conventions?
Thanks
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Oct1-08, 05:03 PM   #2
Recognitions:
You have the correct conventions for optics.
In high energy physics, the point of view is that of the photon, so you do look behind the wave. This means that negative helicity (or left-handed helicity) corresponds to right handed polarization.
Oct1-08, 07:14 PM   #3
Quote by h0dgey84bc View Post
... Thus if the wave was coming toward you down the z-axis you'd see it rotating clockwise. If you were behind the wave you'd see it rotating counter clockwise.
Not per IEEE-STD-145.
[tex]E_{CP}=E_x \pm jE_y[/tex]
Do you understand complex exponentials?
Regards,
Bill
Oct2-08, 10:28 AM   #4
[tex]E_{CP}=E_x \pm jE_y[tex]
Sure. You're referring to the phasor representation?
As long as the convention I'm using with be good with the GRE I'm happy, just don't want to lose marks stupidly for the wrong convention.
Oct2-08, 01:11 PM   #5
Recognitions:
Quote by Antenna Guy View Post
Regards,
Bill
The first post is just the trig representation of your exponentials.
The question was is the + or - for right handed circular polarization.
Oct4-08, 08:01 AM   #6
Quote by clem View Post
Note from phasors that a factor of [itex]j[/itex] is equivalent to a +90deg phase shift.
Assume that the phase convention is such that I am looking in the direction of propogation.
For RHCP, [itex]E_y[/itex] "lags" [itex]E_x[/itex], and a factor of j would rotate the phasor of [itex]E_y[/itex] onto that of [itex]E_x[/itex]. Another way of looking at it is that after a quarter wavelength of propogation, [itex]E_y[/itex] would have the phase that [itex]E_x[/itex] started with.
Hence:
[tex]E_R=E_x+jE_y[/tex]
[tex]E_L=E_x-jE_y[/tex]
If [itex]E_x[/itex] and [itex]E_y[/itex] are co-phase, the total field is linear (i.e. non-rotating). In this case, [itex]E_R[/itex] and [itex]E_L[/itex] are simply conjugates of one-another (same magnitude).
If [itex]E_x[/itex] and [itex]E_y[/itex] differ by exactly 90deg of phase (and have the same magnitude), the total field is either [itex]E_R[/itex] or [itex]E_L[/itex].
In any other case the total field is elliptical, and has both [itex]E_R[/itex] and [itex]E_L[/itex] components.
Regards,
Bill
Oct4-08, 09:32 AM   #7
Recognitions:
Bill: You "Assume that the phase convention is such that I am looking in the direction of propagation." The usual convention in optics is that you are looking at the light coming toward you. This is opposite to the direction of propagation.
You are using the high energy convention for photons, which is fine, but not what the original questioner asked about.
Oct4-08, 10:26 AM   #8
Mentor
Hey,
Yes, it's right-handed. To see this let t=0. As you go in the +z direction, E rotates from +x to +y, then -x, then -y. Letting the fingers of your right hand curl around in the direction of rotation, your right thumb points in the +z direction. The picture is the same as the threading on a standard right-handed screw.
For your other case, the same argument works out if you use your left hand, so it is left-handed circular polarization.
You could also imagine going in the -z direction, these arguments would still work.
Oct4-08, 06:54 PM   #9
The OP never said anything about "optics" (or high energy physics).
I cited an international standard, and (hopefully) followed it accurately.
Regards,
Bill
Thread Closed
Thread Tools
Similar Threads for: Right handed vs Left handed circular polarization
Thread Forum Replies
Are Animals Right or Left-Handed? Medical Sciences 14
left and right handed Medical Sciences 4
Right/Left Handed Systems Linear & Abstract Algebra 2
Being Left-Handed General Discussion 79
Right vs. Left Handed Molecules Chemistry 4
