Calculate Collector Current w/ Emitter @ 100mA - Transistor Switch
  • Thread starter Thread starter Jason7fd
    Switch Transistor
The discussion revolves around calculating the collector current of an N-P-N transistor when the emitter current is specified as 100mA. The context includes a circuit involving a thermistor and resistors, with specific values provided for some components but not all.
  • Participants are attempting to clarify the circuit setup, specifically the roles of the emitter and collector, and the missing value of R2. Questions about the operation mode of the BJT and the relevant equations for collector current are also raised.
The discussion is ongoing, with participants seeking additional information to better understand the problem. Some guidance has been offered regarding the need for knowledge about bipolar junction transistors and their operational parameters, but there is no explicit consensus on how to proceed with the calculations.
There is a noted lack of information regarding the value of R2 and the specific configuration of the BJT. Additionally, some participants express uncertainty about fundamental concepts related to BJTs, indicating a potential gap in background knowledge relevant to the problem.
Jason7fd
http://img300.imageshack.us/img300/2640/17569077cy5.jpg
The transistor is a N-P-N type. When the siren is functional, the resistance of thermistor is 120 ohm. R1 is 600 ohm. The question is "Calculate the collector current if the emitter current is 100mA". I know that current of emitter = current of collector + current of base, but how do I find the base current? Another one, "what is the maximum voltage across R1 if the siren is functional?".
none
none
You didn't provide the value of R2. Also you didn't specify which end of the BJT is the emitter or collector. Is the BJT functioning in forward-active mode?
I have updated the schematic diagram. Sorry, I am not sure what are BJT and forward-active mode. The value of R2 is not provided in this question.
Uh, how are you expected to do this question if you don't know how a bipolar junction transistor (BJT) works in circuits? Do you know the equation for collector current in terms of VBE? What is value of B, the beta parameter of the BJT?
I wish I was taught about this in school but they are not in the syllabus. It is a question from O-level Physics of Malaysia.
Hi, could you post the question exactly as it is ? Because what you have provided so far is insufficient.
  • · Replies 60 ·
18K
