Electrical Engineering MUX help?
The discussion revolves around understanding multiplexers (MUX) in the context of an electrical engineering assignment. Participants explore the internal workings of a MUX, how to derive its function from truth tables and Karnaugh maps (k-maps), and the relationship between these concepts.
  • Homework-related
  • One participant expresses confusion about the internal operations of a multiplexer despite understanding the basic concepts of inputs and selectors.
  • Another participant explains the logic of a MUX, stating that the output depends on the select bit determining which input is passed through.
  • A participant indicates difficulty in transitioning from truth tables and k-maps to the MUX function, referencing a specific problem for context.
  • Further clarification is provided on how truth tables relate to k-maps and how these can be used to derive the MUX function, emphasizing that a MUX operates as a logical device rather than a mechanical switch.
  • One participant details a specific function derived from a k-map, explaining the conditions under which different inputs are selected based on the values of the select bits.
Participants do not appear to reach consensus on the clarity of the transition from truth tables and k-maps to MUX functions, indicating ongoing confusion and differing levels of understanding.
Participants reference specific examples and problems, indicating that their understanding is contingent on the details of those cases. There is an acknowledgment of the complexity involved in visualizing MUX operations beyond basic definitions.
Students studying electrical engineering, particularly those focusing on digital logic design and multiplexers.
MagLok
Here's an image of the assignment: http://img363.imageshack.us/img363/9125/1331011mg1.jpg
1 and 2 specifically..I think I can get the others knowing 1 and 2, ALSO: I don't want the answers, just the method of obtaining it. I'm completely lost with MUX.
Thanks in advance,
-M
EDIT:
I understand the concept of inputs, the selector inputs, and the final values, but what happens inside of a multiplexer? Thanks in advance (again)
-M
The logic of a MUX is pretty simple. Say there are 2 inputs X0 and X1 and one select bit given by S. If S is 0, X0 appears on the output. If S is 1, X1 appears on the output. The logic of this MUX is therefore OUT = SX1 + (~S)X0 because in order for OUT to be true, the select bit must be selecting an input that is true. I have used ~ to mean NOT.
Thanks jhicks, but unfortunately I still don't quite get it.
My notebook was lost earlier this week with examples, and now I just have this problem off of an old test to go by: http://img525.imageshack.us/img525/8118/456456le3.jpg
I understand the k-map and the truth table, but I don't understand how he goes from those to a multiplexer (or how the multiplexer can go to the function.)
Thanks (again) in advance,
-M
Well really the truth table goes to the k-map and the k-map gives you the MSOP (or MPOS) form of the output. You can't view the MUX as some sort of mechanical device that has a little switch that connects to a particular input based on the select bits, it's simply a piece of logic that let's the select bits control which output is expressed.
Ok I'm writing up an explanation for what's happening now. No doubt you come up with the MUX before you come up with the k-map and truth table:
F=(~a)(~c) + ab. a controls select bit 1 and c controls select bit 0. Let's look at the ab term. If a is true, then ~a is false and therefore the value of c doesn't matter because (~a)(~c) will never be true. If b is true, ab is true. If b is false, ab is false. Therefore, if a is true then we wish b to be tied to both inputs that can be selected when a is true because c doesn't matter, so b should be tied to selects 10 and 11
For 00 and 01, on the other hand, consider the (~a)(~c) term. If ~a is true, then (~a)(~c) evaluates to whatever (~c) is and ab will always be false. If ~c is 1 then (~a)(~c) evaluates to true, therefore 00 should be tied to 1. If ~c is 0 (i.e. c=1) then (~a)(~c) evaluates to false always, so tie the input chosen when a=0 and c=1 to 0.
17K
