Troubleshooting Apache HTTP Server Configuration on Linux
  • Thread starter Thread starter karthik3k
    Linux
The discussion revolves around troubleshooting the configuration of the Apache HTTP Server on a Linux system, specifically regarding the display of a custom index.html file instead of the default test page. Participants explore potential misconfigurations in the server's document root settings.
  • One participant indicates that the Apache server is showing a test page instead of the expected index.html file located in /var/www/html.
  • Another participant suggests checking the configuration file to verify the document root, implying it may not be set to /var/www/html.
  • A different participant asserts that the document root is indeed set to /var/www/html, contradicting the previous suggestion.
  • One participant provides a link to an external resource that may assist with the configuration issue.
  • A later post reiterates the suggestion to check the configuration file, humorously noting the off-topic nature of the discussion.
Participants express disagreement regarding the correct document root configuration, with some asserting it is set correctly while others question this assumption. The discussion remains unresolved.
There may be limitations related to the visibility of configuration settings, potential overrides in other configuration files, or the presence of additional Apache modules affecting the server's behavior.
karthik3k
My RH9 is preinstalled with Apache http server.
If i connect to 127.0.0.1 its showing the test page. But i have an index.html file in /var/www/html/ folder. And this folder path is given as the document root in httpd.conf file.
I donno from where that test page comes out and i donno how to display my index.html file.
It doesn't work even if i use 127.0.0.1/index.html
Somebody please help...
Thanx
Computer science news on Phys.org
check the .conf file to see where Apache's root directory is. It apparently isn't /var/www/html.
- Warren
No. It is /var/www/html
Maybe this will help:
http://myy.helia.fi/~karte/kurssit/lamp-linux-apache-mysql-php-quickstart.html
An Unfortunate off-track :-p
14K
10K
  • · Replies 19 ·
10K
