| Thread Closed |
perfectly elastic collision |
Share Thread | Thread Tools |
| Nov3-08, 12:08 PM | #1 |
A 15 g ball is fired horizontally with speed v0 toward a 117 g ball hanging motionless from a 1.53-m-long string. The balls undergo a head-on, perfectly elastic collision, after which the 117 g ball swings out to a maximum angle θmax=53°. What was v0? 2. Relevant equations h=L(L-cos(theta) V=Square root of (m*g*h/(.5*M) little m is ball moving and M is the ball not moving (v2x)f=2m1/m1+m2 (V1x)i 3. The attempt at a solution Im not sure if im using the right equations and whether the angle given is the one we use in the equation, or if we have to subtract it from 90 first |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Nov3-08, 12:41 PM | #2 |
Recognitions:
Initial KE is 1/2*m*v2 The second is that the angle because it is hanging is with the vertical. Hence the height should be given by the Cosθ times the string length subtracted from the length. (h = length - projection of the string to the vertical.) So ... 1/2*m1*v2 = m2*g*(L - L*cos53) v2 = 2*(m2/m1)*g*(L-L*Cos53) |
| Nov3-08, 01:07 PM | #3 |
is this the equation i use to get the answer or do i have to plug it into another one |
| Nov3-08, 02:09 PM | #4 |
Recognitions:
perfectly elastic collisionWith that final velocity for the stationary ball after impact and the usual equations for conservation of energy and momentum, you should now have 2 equations and 2 unknowns, one of which is the Vo that they ask for. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: perfectly elastic collision
| Perfectly Elastic Collision Problem | Introductory Physics Homework | 15 | ||
| [SOLVED] Perfectly Elastic Collision | Introductory Physics Homework | 5 | ||
| perfectly elastic collision | Introductory Physics Homework | 7 | ||
| Mastering Physics: Collision on an incline plane and perfectly inelastic collision | Introductory Physics Homework | 2 | ||
| perfectly elastic collisions | Introductory Physics Homework | 10 | ||
