Projectile Motion in Elevator: Peach Pit Launch Homework
The problem involves projectile motion, specifically analyzing the trajectory of a peach pit thrown from a moving elevator. The scenario includes both horizontal and vertical components of motion, with varying initial velocities depending on the elevator's state (stationary or moving upward).
  • Participants discuss splitting the motion into vertical and horizontal components to analyze the time of flight and horizontal distance. There are attempts to apply kinematic equations, particularly for vertical motion, and questions arise regarding the appropriate formulas for different scenarios.
Some participants have successfully calculated the time and distance for the first part of the problem, while others express confusion regarding the subsequent parts involving the moving elevator. Guidance has been offered on how to approach the problem by considering the components of motion.
Participants note uncertainty regarding the application of formulas for the second scenario where the elevator is moving upward, indicating a need for clarification on how to handle the initial velocity components.
halo9909
A rude tourist throws a peach pit horizontally with a 7.0 m/s velocity out of an elevator cage.
(a) If the elevator is not moving, how long will the pit take to reach the ground, 11.0 m below?
s
(b) How far (horizontally) from the elevator will the pit land?
m
(c) He throws the next pit when the elevator is at the same height but moving upward at a constant 9.5 m/s velocity. How long will it take this pit to land?
s
(d) How far away will this pit land?
X Y
d h
v vi
t vf
t
a
d=.5at^2
basic trigonometry
I am unsure how to approach this, since I don't understand this, what would need tobe done to find time in part1
Start my splitting the motion into two components, vertical and horizontal motion. Now, considering the vertical motion only, how long will it take the peach to hit the ground?
yeah i got part a and b
t=Squareroot(2d/9.8)
and got the "t" to be 1.498sec and multplied the time by 7 and got "b" which is 10.483m
but for the other two it is left me confused, on how to use like forumulas
In the previous case, the initial velocity only had an horizontal component, but in the current case the initial velocity has both a horizontal and vertical component. However, the approach is much the same.
Start by splitting the motion into the horizontal components. Which kinematic formula do you think would be appropriate for part (c)?
