Is My Veritech 2GB Flash Memory Corrupted?
  • Thread starter Thread starter hazim
    Flash Memory
The discussion revolves around the issue of a Veritech 2GB flash memory that is recognized by computers but fails to open, prompting a message about formatting. Participants explore potential causes, including file system corruption and hardware failure, and suggest various approaches to resolve the problem.
  • Experimental/applied
  • One participant suggests that a virus may have corrupted the FAT32 file system, leading to the issues experienced.
  • Another participant doubts the presence of a virus and questions whether the correct removable disk is being accessed, suggesting the possibility of confusion with other drives.
  • A participant mentions that the flash memory may be damaged or that poor software in the controller chip could be causing the problem, indicating that such devices often have reliability issues.
  • One participant provides a link to a website that explains how to format a flash drive, implying that following those steps might help.
  • The original poster reports that attempts to format the drive have failed, leading to the conclusion that the memory may be broken, while also noting the low cost of replacement drives.
Participants express differing views on the cause of the issue, with some attributing it to potential virus corruption and others suggesting hardware failure. The discussion remains unresolved regarding the exact cause and solution.
Participants mention various methods for formatting the flash memory, but there is no consensus on their effectiveness. The discussion highlights the uncertainty surrounding the reliability of flash memory devices.
hazim
It is a Veritech 2GB flash memory.. I tried it on some computers.. they recognize it, but when I double click it to open it, it doesn't open and a message box says that it's not formatted, do you want to format it?... I tried to scan it by antivirus but nothing appeared... I tried to format it by right clicking it.. it didn't work.. I tried formatting it from the command prompt but it even didn't work...
As you can see in the attached picture, the disk is shown full and it says 0 bytes used! also it shows no file system! I think a virus corrupted the file system FAT32. What do you think and how could I fix this flash memory?? any help?
Computer science news on Phys.org
If it came with a disk you could format it from that. You might be able to download a program to format it. I doubt that it has a virus.
Are you sure that you are looking at the right removable disk, because F: could be a card slot or something else that is empty. What is MR Hazim?
It's me Mr. Hazim :)... this is my flash not anything else. No disk came with it.. Could you please give me a link for a program to format the flash memory?
Just right click on it and select format.
make sure it says fat32 and uncheck the quick format box.
The problem is likely to be due to either damage to the stick or to poor software in the controller chip on the stick. These devices are built to very low margins and the implementation of the disk emulator in them isn't always perfect, often they will wokr on one machine and not another or only on one type of windows
This website explains it step by step.
http://www.ehow.com/how_2006214_format-flash-drive.html"
It didn't work...format failed... I think the memory is broken.. It doesn't matter, here 2GB flash memory costs only 5$... 4GB 7$ with warranty.. Anyway thank you all very much
  • · Replies 20 ·
