Register to reply
Equipotential Contour Theory
by TJDF
Tags: contour, equipotential
Share this thread:
TJDF
#1
Feb18-09, 08:13 PM
P: 27
The lines show equipotential contours in the plane of three point charges, Q1, Q2, and Q3. The positions of the charges are marked by dots. The values of the potentials are in kilovolts as indicated, e.g., +5 kV, −5 kV; the contour interval is 1 kV. The letters denote locations on the contours. For distances use the scale below the picture, to an appropriate accuracy. Select all the correct statements, e.g., AB.
A) The electric field at g is zero.
B) Charge Q2 is the largest negative charge.
C) Q1 is a negative charge.
D) The electric field at d is stronger than at b.
E) Charge Q3 is the largest positive charge.
F) The force on an electron at g points to the top of the page.
2. Relevant equations
No equations necessary, theory only.
3. The attempt at a solution
Last Answer: CE
Last Answer: BCE
Last Answer: BCEF
Last Answer: ABCEF
Last Answer: ABCE
Last Answer: ACE
Last Answer: ACEF
I just don't know the theory behind this, I've been tried, failed, and I don't understand. If anyone can explain the concepts and what the right answer is, I'd really appreciate it.
Phys.Org News Partner Science news on Phys.org
Fungus deadly to AIDS patients found to grow on trees
Canola genome sequence reveals evolutionary 'love triangle'
Scientists uncover clues to role of magnetism in iron-based superconductors
TJDF
#2
Feb18-09, 09:32 PM
P: 27
Anyone?
AEM
#3
Feb18-09, 09:36 PM
PF Gold
P: 362
Here's some relevant theory. Taking your reference position to be V = 0 at infinity, the electric potential, V, is given by
[tex] V = \frac{1}{4 \pi \epsilon_o} \frac{q}{r} [/tex]
This is related to the electric field by
[tex] E = - \nabla V [/tex]
which for a point charge can be rewritten as
[tex] E = - \frac{1}{4 \pi \epsilon_o} \frac{\partial}{\partial r} \frac{q}{r} [/tex]
calculating out the derivative, you get
[tex] E = \frac{1}{4 \pi \epsilon_o} \frac{q}{r^2} [/tex]
The lines drawn on your diagram are lines of constant electric potential. They are analogous to lines of constant altitude on a topographic map. The closer together the equipotential lines are, the larger the gradient, so the stronger the electric field is. The same thing is true on a topographic map --steep hills are indicated by contour lines close together.
Hope this helps.
TJDF
#4
Feb18-09, 09:49 PM
P: 27
Thanks.
I still don't know how each would apply to the questions though.
---> I can't tell whether this is true or not, I'm starting to have my doubts, but I can't explain why.
---> I was told the diameter of the charge means it has more strength, therefore Q1 is the largest negative charge, so this is definitely false... right?
---> True. Unless I've been reading this wrong.
---> I thought because they are on the same contour lines, the fields are the same, but again, like A, I don't get the reasoning, but judging by the fact that closer equipotential lines are, then stronger gradients, this must be true.
---> It's the only positive charge. True.
---> False, I'm pretty sure on this one now from my reading.
TJDF
#5
Feb18-09, 09:59 PM
P: 27
Is the electric field zero if the equipotential contour line is 0 volts?
How does the diameter of the circle affect the strength of the charge?
Are electric fields on the same contour line equal or judging by the fact that closer equipotential lines are, then stronger gradients, then can they be different?
What about the force on an electrons and why they would point up/down?
TJDF
#6
Feb18-09, 11:04 PM
P: 27
Wait... are the correct answers C, D, and E?
C is true because q1 is a negative charge.
D is true because the contour lines are closer together, and D is closer to the positive charge meaning the field must be stronger because... the charge is stronger.
E is true because q3 is the only positive charge.
A is false because there are positive charges and negative charge and so it naturally cannot be 0.
B is false because q1 has a large radius and therefore, looking at the formula rearranged, that would make q larger.
F is false because the electron should point down in alignment with its charge.
Is this right?? unfortunately Im not given the correct answers and I cant find anything that explains this clearly to me, usually I learn through examples, but I can't find any. Can anyone confirm or disprove my reasoning?
AEM
#7
Feb19-09, 08:48 AM
PF Gold
P: 362
Quote Quote by TJDF View Post
Yes, I agree
I'll go along with these conclusions, too
Correct, electric field lines start on positive charges and end on negative charges (by convention) By the way you will eventually run into situations where the electric field is zero, but the electric potential is NOT. That will occur with conductors. Keep an eye out for it
Correct. A simple way to show this is to assume two situations, one with charge -q and one with charge -2q and compute the radius for a -5 volt contour line. Then compare the values you get.
F is false because the FORCE ON THE electron should point down in alignment with its charge.
Correct, although I edited your sentence
Obviously, my responses are in black
TJDF
#8
Feb19-09, 10:24 AM
P: 27
Thanks so much!!!
I understand it perfectly now!!!
Register to reply
Related Discussions
Please explain equipotential surfaces/ contour maps Introductory Physics Homework 3
Equipotential Lines General Physics 0
Equipotential surfaces Advanced Physics Homework 8
Equipotential diagram Advanced Physics Homework 2
