| Thread Closed |
MRI Imaging |
Share Thread | Thread Tools |
| Jun21-09, 04:11 AM | #1 |
MRI Imaging
What is the source of noises we hear during MRI imaging?
Thanks! |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Jun21-09, 02:57 PM | #2 |
Big electromagnets create powerful fields, and not very stable ones on a small scale, so might be that oscillations can occur as the conductor has it's own elasticity.
Air might get ionized. I've never had an MRI but there might be a small 50 or 60 Hz humm from the power source which should be powerful at least. Electrics have a few specific noises. |
| Jun21-09, 03:16 PM | #3 |
I've never had an MRI, but I suspect most of the noise comes from the compressor for the cryocooler (which is part of the cooling system for the magnet); they tend to be extremely noisy.
| Jun21-09, 05:34 PM | #4 |
Mentor
MRI Imaging
No, it wouldn't be the utilities - they are housed in a separate room.
| Jun21-09, 05:45 PM | #5 |
Recognitions:
MRI systems require a very strong magnetic field to align the magnetic moments ("spins") of the hydrogen nuclei in your body. In a typical system this field is produced by a superconducting solenoid (you slide into the cylindrical cavity at the center of the magnet). The frequency of magnetic resonance is directly proportional to the field strength. Big GE systems, for instance, use a 1.5T field and excite/detect spins at 64 MHz. To image, the locations of spins in the body must be differentiated. This is done by adding weaker position-dependent magnetic fields on top of the static strong one, so a nucleus's magnetic resonance frequency depends on where it is. Field gradients are applied in three orthogonal directions (x, y and z) in a certain time sequence, and, to create an image rapidly, they are switched on and off over and over very quickly. This is how the intensity in each pixel of the image is built up. Ok, now to the noise. The gradients are produced by big electrical coils that also sit in the main bore. When current (typically around 150A) flows, the wires feel a large sideways Lorentz force because they are in a strong static field. Consequently, these coils are wound on strong formers and are potted to minimize wire movement. Because the current is turned on and off very rapidly, however, the wires exert a strong impulsive force that is heard as a bang even though gross wire motion is controlled. The repetitive banging you hear is the three coils being pulsed over and over with various strengths, timings and sequences to build up the image. Here is a two-page summary of MRI. The second page shows a sketch of the main magnet and the gradient coils. http://people.ee.duke.edu/~jshorey/M...page/work.html Here's a much more detailed tutorial if you want to learn more about spins, nuclear magnetic resonance, and how it is used to produce images: http://orthopedics.about.com/gi/dyna...ks.com/mri.htm |
| Jun21-09, 06:02 PM | #6 |
I had an MRI many years ago and I wondered about that myself. It sounded like a mechanical thump or knock with a frequency of about four thumps per second. But it was a long time ago so I'm not sure about the frequency.
I thought it may be the current in the magnets but I wasn't sure. I once worked in a factory that used large electric spot welders. They made a similar thumping sound. |
| Jun21-09, 06:07 PM | #7 |
Mentor
Considering the physics it is actually amazing that they are not louder. The manufacturers go to great lengths to reduce acoustic noise by making it stiff and even encasing it in vacuum, but the power amplifiers that drive the gradient coils are basically beefed up audio amplifiers. Many modern systems have over 1 MW worth of amplifiers! I have always wanted to hook them up to a real huge sound system
| Jun21-09, 07:33 PM | #8 |
Recognitions:
DaleSpam, I wouldn't say it "works exactly the same way as a speaker." The Lorentz force powers them both, but a speaker is a linear device--the motion of the diaphragm is proportional to the voice coil current--while the MRI gradient coil produces something closer to an acoustic shock wave. Also, the gradient coils are not encased in a vacuum.
| Jun21-09, 08:15 PM | #9 |
Mentor
As you say, the physical principle behind both is the same. Speakers aren't really linear either, as any audiophile knows. It is just different degrees of non-linearity.
| Jun21-09, 09:19 PM | #10 |
Recognitions:
| Jun22-09, 02:02 AM | #11 |
![]() And that summary gives a link to several audio segments of the noise, near the bottom of "Imaging Hardware: Safety", at http://www.cis.rit.edu/htbooks/mri/c...chap-9.htm#9.6 in the very detailed "The Basics of MRI" by Joseph P Hornak, and also near the bottom of "Your MRI Exam" at the same site, at http://www.cis.rit.edu/htbooks/mri/chap-13/chap-13.htm ![]() The former link also contains the following cautionary tales: ![]() |
| Jun24-09, 10:09 AM | #12 |
Thank you very much!
| Thread Closed |
| Tags |
| mri imaging |
| Thread Tools | |
Similar Threads for: MRI Imaging
| X-ray imaging | Nuclear Engineering | 3 | ||
| Neutron imaging | Quantum Physics | 3 | ||
| X-ray imaging | General Physics | 2 | ||
| RF imaging | Electrical Engineering | 3 | ||
