Shear Flow in a Tube/Pipe: Understanding the Effects of Shear Force on Point B
  • Thread starter Thread starter lizzyb
    Flow
The discussion revolves around the calculation of shear flow in tubes and channels subjected to shear forces, specifically addressing the conditions under which the shear force should be modified for calculations at specific points. Participants explore the application of shear force values in different scenarios and the implications for determining shear flow at various points in the structures.
  • One participant questions the application of dividing the shear force by 2 in certain situations, noting inconsistencies in when this modification is necessary.
  • Another participant clarifies that the total shear flow on both sides of the tube should be divided by 2 when calculating shear flow at point B, as the question specifically asks for that side.
  • A participant expresses confusion about why the modification of shear force (P = V/2) is not applied in all cases, despite arriving at correct answers without it in some instances.
  • One participant asserts that V and I remain constant across a cross-section, indicating that Q varies based on the chosen section cut, and emphasizes that the total shear flow at a sectioned-off portion is determined by the shear flow at point B.
  • There is a suggestion that the wording of one of the questions could lead to multiple interpretations regarding whether the shear flow refers to the entire channel or just one flange.
Participants express differing views on the application of shear force modifications in calculations, with some agreeing on the need to divide by 2 in specific contexts while others question the consistency of this approach. The discussion remains unresolved regarding the criteria for applying these modifications.
Participants note that the interpretation of questions can lead to different approaches in calculating shear flow, highlighting the importance of precise wording in problem statements. There is also mention of varying definitions and interpretations of Q in relation to shear flow calculations.
lizzyb
Question
Given that the tube is given a shear force V = 8 kip, what is the shear flow at points A and B?
http://img268.imageshack.us/img268/144/scannedimage031.jpg
Work Completed Thus Far
I determined I:
http://img187.imageshack.us/img187/9821/scannedimage033.jpg
Q for a circle in general (second moment of inertia of an area for a circle):
http://img43.imageshack.us/img43/2042/scannedimage034.jpg
Q for this particular problem:
http://img30.imageshack.us/img30/5831/scannedimage035.jpg
Q for point B:
http://img257.imageshack.us/img257/6681/scannedimage036.jpg
q for point B:
http://img21.imageshack.us/img21/5307/scannedimage037.jpg
Yet the solution is twice what is in the back of the book.
The Big Question
It seems that for some problems we take into account that the shear force in a specific part of the object (pipe, or wooden structure) as being, say half or a third of the entire V - like in this question, take V = P/2 where P is the original, given V (P = 8 kip). But other times I've arrived at the correct answer by using the original, unmodified V.
What gives?
lizzyb: Your answer is correct for the total shear flow on both sides of the tube at y = 0. But the question asks for the shear flow on only side B, not both sides. Therefore, divide your answer by 2. Also, Q is not called second moment of inertia of area; look up the correct name.
Thank you for your response. I understand why I should take P = V/2 and use P in determining the shear flow however I do not understand why that should be applied in some situations and not employed in others. Here is a case in point:
Question
Determine the maximum shear flow in the channel.
http://img223.imageshack.us/img223/6509/scannedimage039.jpg
Attempt at Solution
I actually have the right answer, but why wouldn't I do the P = V/2 thing in this situation?
http://img223.imageshack.us/img223/571/scannedimage040.jpg
http://img443.imageshack.us/img443/1425/scannedimage041.jpg
http://img33.imageshack.us/img33/1313/scannedimage042.jpg
http://img443.imageshack.us/img443/5933/scannedimage043.jpg
Again, this is the right answer but why didn't I take P = V/2 in this situation? Thank you.
Very good. Can you post the exact wording of the given question for post 3, so I can see how they worded it?
Question #3 (exact wording)
The channel is subjected to a shear of V = 75 kN. Determine the maximum shear flow in the channel.
Question #1 (exact wording)
The pipe is subjected to a shear force of V = 8 kip. Determine the shear flow in the pipe at points A and B.
V and I are always constant on a cross section; therefore, you never divide V by 2. Q varies depending on your section cut(s).
Therefore, in question 1, notice the actual section cut for Q is at B and A, to section off one fourth of the tube. But the shear flow at A is zero; therefore, the total shear flow on the sectioned-off portion of the cross section is the shear flow at B.
Question 3 is actually poorly written, because it can be interpreted two ways. It can mean the shear flow on the entire channel, or it can mean the shear flow on one flange. Let's assume they mean the shear flow on one flange. As always, V never changes. We see Q is half of what it would be for both flanges. Hence, q is half of the shear flow on the entire channel.
Yes that explains it quite well; thank you.
33K
