How to check if Lagrangian is parity invariant?
The discussion centers on the parity invariance of a specific Lagrangian involving fermionic fields and gamma matrices. Participants explore the implications of parity transformations on the Lagrangian and the behavior of various components under these transformations, including spinors and derivatives. The conversation includes technical reasoning and challenges related to the treatment of left and right-handed fermions, as well as the mathematical formalism involved.
  • One participant argues that the Lagrangian should violate parity but finds that it appears invariant under their calculations, raising questions about the transformation of the fields and derivatives.
  • Another participant suggests that the gamma matrices do not change under parity transformations, while the spinors do, leading to a discussion about the proper treatment of these components during transformations.
  • There is a claim that when substituting for fields in the Lagrangian, the derivatives should remain with respect to the original coordinates, not the transformed ones, which raises questions about the consistency of this approach.
  • Some participants discuss the implications of treating left and right-chiral fermions differently and how this relates to the overall parity violation in the theory.
  • One participant clarifies that the transformation of derivatives under Lorentz transformations involves both the argument and the transformation matrix, leading to a cancellation that preserves the form of the derivative.
  • Another participant emphasizes that the parity operation should affect all components of the Lagrangian, not just the fermionic fields, suggesting a broader interpretation of parity transformations.
  • There is a challenge regarding the treatment of derivatives under parity transformations, with differing views on whether they should change in the same way as the fields.
Participants express differing views on how to properly apply parity transformations to the Lagrangian and its components. There is no consensus on whether the derivatives should change alongside the fields or remain fixed with respect to the original coordinates. The discussion remains unresolved with multiple competing interpretations.
Participants note that the treatment of left and right-handed fermions is crucial to understanding parity violation, and there are various definitions and interpretations of parity operators that may affect the conclusions drawn. The mathematical steps involving transformations are complex and depend on specific assumptions about the fields and their interactions.
RedX
The Lagrangian [tex]\mathcal L =\psi^{\dagger}\gamma^0 \gamma^\mu (1-\gamma^5)\partial_\mu \psi[/tex] should violate parity, but I'm getting that it doesn't.
[tex]\psi(x)[/tex] changes to [tex]\gamma^0 \psi( Px)[/tex] where Px=(t,-x) and x=(t,x).
[tex]\gamma^j[/tex] goes to [tex]- \gamma^j[/tex], while [tex]\gamma^0[/tex] stays the same. [tex]\gamma^5[/tex] goes to [tex]-\gamma^5[/tex].
[tex]\partial_j[/tex] goes to [tex]-\partial_j[/tex] while [tex]\partial_0[/tex] stays the same.
So [tex]P^{-1}\mathcal L P=(\psi^{\dagger}(Px)\gamma^0)\gamma^0 \gamma^\mu (1+\gamma^5)\partial_\mu (\gamma^0 \psi(Px))[/tex] (the contraction between [tex]\gamma^\mu[/tex] and [tex]\partial_\mu[/tex] stays the same under parity).
So: [tex]P^{-1}\mathcal L P=(\psi^{\dagger}(Px) \gamma^0 \gamma^\mu (1-\gamma^5)\partial_{P\mu} \psi(Px)[/tex]. Here [tex]\partial_{P\mu}=\frac{\partial}{\partial (Px)^\mu}[/tex]
Therefore doesn't [tex]P^{-1}\mathcal L(x) P= \mathcal L(Px)[/tex]? Which means the Lagrangian doesn't change under parity?
I half figured it out. The gamma matrices, being Lorentz singlets, don't change under Lorentz transformation or parity transformation. But the spinors that they're sandwiched between do change. However, you can leave the spinors alone (except the argument of the spinors) and do an inverse change of the gamma matrices instead - this is equivalent to performing a Lorentz transformation on the entire expression. For technical reasons, it's not an inverse change of the gamma matrices but a forward change (this has to do with how the gamma matrices are constructed from the Pauli symbols). So I cannot change both the spinors and the gamma matrix, so I only need to change the gamma matrix and forget about the extra [tex]\gamma^0[/tex] that multiplies the parity-changed spinor.
But now the claim is that in an expression like:
[tex]P^{-1} \mathcal L(x) P = \mathcal L(Px)[/tex]
the right hand side means to substitute Px for x in all the fields only, and not any derivatives!
So if the Lagrangian is [tex]\mathcal L(x)=i\psi^{\dagger}(x)\gamma^0\partial_{\mu}\psi(x)A^{\mu}[/tex], then [tex]\mathcal L(Px)=i\psi^{\dagger}(Px)\gamma^0\partial_{\mu}\psi(Px)A^{\mu}(Px)[/tex], and the partial derivative is with respect to x, and not Px. Why is this true? When you plug in Px in L to get L(Px), shouldn't the derivative change to be with respect to Px, and not x?
Part of what you say is right. The parity violation in question has to do with the left and right-chiral fermion fields not being on equal footing, not that spacetime itself has violation of parity. There are a variety of "parity operators" can be defined in a variety of ways. In our case, to verify violation of *fermion parities*, the parity operator acts on the fields as you wrote down.
The transformation of the term [tex]A:=P[\bar{\Psi}(x)\gamma^{\mu}\partial_{\mu}\Psi (x)]P[/tex]
becomes [tex]\bar{\Psi}(\bar{x})\gamma^{0}\gamma^{\mu}\gamma^{0}\partial_{\mu}\Psi(\bar{x})[/tex] due to the way P's act on the *fields* [and x-bar = (t,-x)].
But now [tex]\gamma^{0}\gamma^{\mu}\gamma^{0}\partial_{\mu}=\gamma^{\mu}\bar{\partial}_{\mu}[/tex] where the bar over the derivative signifies "w.r.t. x-bar". You can verify this last expression by expanding in terms of the index "0" and spatial index "i" and using [tex][\gamma^{0}]^{3}=\gamma^{0}; \gamma^{0}\gamma^{i}\gamma^{0}=-\gamma^{i}[/tex]. So this first term satisfies PA(x)P=A(x-bar), where x-bar appears also in the derivative.
Similarly you can see that the second term [tex]B:=P[\bar{\Psi}(x)\gamma^{\mu}\gamma^{5}\partial_{\mu}\Psi(x)]P[/tex] becomes [tex]-[\bar{\Psi}(\bar{x})\gamma^{\mu}\gamma^{5}\bar{\partial}_{\mu}\Psi(\bar{x})][/tex] simply due to the extra gamma-5 matrix that you have to anti-commute over the gamma-0 in the factor [tex]\gamma^{0}\gamma^{\mu}\gamma^{5}\gamma^{0}[/tex]. Therefore, the second term *doesn't* satisfy PB(x)P=B(x-bar).
So the partial derivative here has not transformed, so that it's with respect to x and not x_bar?
So the parity operation does not change the partial derivative after applying it? It's only after you make some manipulations later on, that the partial derivative gets changed, but not immediately from the parity operator?
Okay, I figured it out if anyone else was wondering the same question. Take a scalar field [tex]\phi(x)[/tex] for simplicity. How does its partial derivative transform under Lorentz transformation?
[tex]\partial^\mu \phi(x) \rightarrow \Lambda^{\mu}_{\nu}\bar{\partial}^\nu \phi(\Lambda^{-1} x)[/tex]
The bar on the partial means with respect to [tex]\Lambda^{-1} x[/tex]. So the partial derivative does change, but in two ways, inside the argument (the bar) and outside (the Lambda), such that there is cancellation and you can treat it as if nothing changes!
[tex]\partial^\mu \phi(x) \rightarrow \Lambda^{\mu}_{\nu}\bar{\partial}^\nu \phi(\Lambda^{-1} x)= \partial^\mu \phi(\Lambda^{-1} x)[/tex]
Careful here. The Lorentz transformation is not what the original question was dealing with...the full spacetime parity of the interactions are not what's in question, rather the symmetry or lack thereof in the interaction's treatment of left/right-handedness of the spin-1/2 fields (though this has to do indirectly with spacetime properties since spin is such a property). Anyway, that means we act with a parity operator on the fermionic fields. All this ends up showing mathematically is the property that left and right handed fields are treating unequally by the weak interaction.
As for the Lorentz transformation you wrote down, the quantity is a vector and so should not transform as a scalar like you wrote. [tex]\partial_{\mu}\phi(x) \rightarrow (\Lambda^{-1})^{\nu}_{\mu}\partial_{\nu}\phi(\Lambda^{-1}x)[/tex] where the derivative is still WRT x.
I think when performing a transformation on the Lagrangian, everything in the Lagrangian gets transformed, and not just fermionic fields. Otherwise it would not be called parity, but "parity with respect to just fermionic fields". Of course you can always make such a transformation if you want, and if the Lagrangian is invariant, then that is a symmetry. But for parity in general, I think you have to transform everything in your Lagrangian.
javierR said:
As for the Lorentz transformation you wrote down, the quantity is a vector and so should not transform as a scalar like you wrote. [tex]\partial_{\mu}\phi(x) \rightarrow (\Lambda)^{\nu}_{\mu}\partial_{\nu}\phi(\Lambda^{-1}x)[/tex] where the derivative is still WRT x.
When the derivative is WRT to [tex]\bar{x}^\mu[/tex], then it transforms as a vector. But if you were to do analogously what you did with Lorentz transformations with parity by replacing [tex]\Lambda[/tex] with the parity matrix P, then
[tex]\partial_{\mu}\psi(x) \rightarrow P_{\mu}^{\nu} \partial_{\nu}\psi(P^{-1}x)[/tex]. So an extra P comes out that you didn't have when you parity-transformed the Lagrangian, so this would change your answer.
  • · Replies 24 ·
