Why Do I Struggle to Choose the Correct u and dv in Integration by Parts?
The discussion revolves around the challenges faced in selecting appropriate terms for \( u \) and \( dv \) in the context of integration by parts, particularly when dealing with logarithmic and polynomial functions. Participants are exploring the nuances of this integration technique.
  • Conceptual clarification, Assumption checking, Exploratory
  • Some participants suggest using simpler functions for \( v \) and question the original poster's choices for \( u \) and \( dv \). Others discuss the importance of recognizing the difference between products and compositions of functions in integration by parts. There are mentions of the LIATE rule for choosing \( u \) and considerations about the appropriateness of certain examples for illustrating the technique.
The discussion is ongoing, with various participants providing insights and hints to guide the original poster. There is a mix of suggestions and clarifications regarding the correct application of integration by parts, but no consensus has been reached on a single approach.
Participants note that the original poster has access to a solution manual, which may influence their understanding. There is also mention of the class not having covered certain concepts yet, which may contribute to the confusion regarding composition and product laws in integration.
pillar
Find
http://img214.imageshack.us/img214/4186/problemm.png
udv=uv-ƒvdu
lndx=dv
(1/X)=v
u=x^2+2
du= 2x^2
I looked in the solutions manual and I don't get, why do I keep picking the wrong u & dv?Can someone please show an example on how to pick the right term for u and dv?
Thanks in advance.
From my Calculus text,
Let u = Ln(x) and let dv = x^n
In general always let v be the easier function to integrate.
Thanks
Matt
Hi pillar! :smile:
(have an integral: ∫ and try using the X2 tag just above the Reply box :wink:)
Try the obvious … u = 1 :wink:
Integration by parts is for PRODUCTS of functions, not COMPOSITIONS. Do you see your error in assigning your u and dv?
The integrand is a composition [tex]\ln x[/tex] and [tex]x^2 +2[/tex]...not a product of the two.
I'll get you started:
On the face of it, we only have ONE function. But if we multiply the integrand by 1, then it's unchanged, right? Well then, we have the product of TWO functions! One is [tex]\ln \left(x^2 +2\right)[/tex] and the other is 1!
Let [tex]u = \ln \left(x^2 +2\right)[/tex] and [tex]dv = 1 dx[/tex]. Then [tex]du = 2x / \left(x^2+2\right)[/tex] and [tex]v=x[/tex]. Then...
Hi union68! :smile:
Please don't provide full (or almost-full) answers …
just give enough to get the OP going again! :wink:
(the OP is still offline, so can you edit a bit?)
pillar mentioned having the solution manual, I highly doubt I gave more info then what was in there...except for the last hint. I'll yank that.
The solution is rather detail (camera not working) and the class hasn't gotten this far yet.
The teacher didn't talk about composition and product laws. Instead what I was able to gather was that you give U to the one easiest to integrate and keep simple to integrate stuff simple.
This integration requires integration by parts, a polynomial long division, and two different integration substitutions. I am curious why this example was chosen to illustrate integration by parts as it is the least interesting part of the solution.
--Elucidus
--Elucidus
Maybe to show 1 could be a dv or something.
Yes, dv = 1 … carry on from there. :smile:
Apparently model my book goes by for choosing u is LIATE (Logmetric.Inverse Trig.Algebraical.Trig.Exponential function)
ok … well, add 1 to the list :smile:
(it does come up quite often)
There are no "composition or product laws" that need to be talked about. The formula for integration by parts is actually derived from the product rule for differentiation, but never mind that. You don't need to know that at this point. Just remember that integration by parts is for integrals of the form
[tex]\int f \left(x\right) g \left(x\right) \ dx,[/tex]
and typically NOT
[tex]\int f \left( g \left(x\right) \right) \ dx.[/tex]
It's usually used where the standard u-substitution from calc II fails. If you wanted to use integration by parts for the second integral (which is like the question you posted!) you CANNOT set [tex]u = g \left(x\right)[/tex] and [tex]dv = f \left(x\right)[/tex]. Look at these integrals...
[tex]\int x \cos x \ dx[/tex]
and
[tex]\int x \cos x^2 \ dx.[/tex]
They look similar, but use different techniques. Can you recognize why?
Part of learning all these rules is also learning where and under what conditions each rule can be applied. This is where your error was.
  • · Replies 22 ·
