What Calculations Are Needed to Achieve Equilibrium in These Statics Problems?
  • Thread starter Thread starter Aaron
    Couple Statics
The discussion revolves around statics problems involving equilibrium calculations for mechanical systems, specifically focusing on a couple required to maintain equilibrium in two different scenarios involving rods and a double toggle mechanism.
  • Participants explore the forces and moments acting on the systems, with one original poster attempting to calculate moments and forces for equilibrium. Questions arise regarding the relevance of external forces and the complexity of the equations needed to solve the second problem.
Some participants have provided insights into their thought processes and calculations, with one indicating a realization about the need for perpendicular distances in their calculations. Others are questioning the approach to balancing forces and moments, indicating a lack of consensus on the best method to simplify the problem.
There is mention of neglecting friction and a focus on internal forces in the first problem. The second problem appears to involve a complex system with multiple forces and moments, leading to a potentially overwhelming number of equations.
Aaron
Hi, I have a couple of questions from a statics assignment that I'm in need of help on. Here's what I have so far:
http://216.170.11.226/pub/6131.jpg
Two rods are connected by a slider block as shown. Neglecting the effect of friction, determine the couple Ma required to hold the system in equilibrium.
And this is what I believe the forces are:
http://216.170.11.226/pub/6131-2.jpg
It would seem to me that the external forces are irrelevant to this problem, but I'm guessing not. What I came up with for this problem is:
Sum of moments about B=0 => -25+Nd*271.89=0 => Nd=0.0919
Sum of moments about A=0 => -.0919*150+Ma=0 => Ma=13.79 N*m
I know the answer is Ma=15.22 N*m. I'm guessing that I also need to consider external forces or something.
The next problem is
http://216.170.11.226/pub/6129.jpg
The double toggle mechanism shown is used in a punching machine. Knowing that the links AB and BC are each of length 150 mm, determine the couple M required to hold the system in equilibrium when Phi=20 (degrees).
Once again, my analysis of the problem is:
http://216.170.11.226/pub/6129-2.jpg
Obvious things are:
Dy+Ey+Ay+800=0
Dx+Ex+Ax=0
sum of moments about B of AB=0 => M+By*150*cos(30)+Bx*150*sin(30)=0
Since AB is a two-force body, Bx=B*cos(30), By=B*sin(30) and A=-B.
B'x=-Bx
B'y=-By
Cx=C*cos(30)
Cy=C*sin(30)
sum of moments about C of BC=0 => -B'x*150*sin(30)+By*150*cos(30)=0
sum of moments about B of BC=0 => -Cy*150*cos(30)+Cx*150*sin(30)=0
And so on and so forth. If I continue in this manner I figure I'll end up with something around 24 equations, there has got to be a simplier method. Any idea what that might be?
Any hints or help would greatly be appreciated.
Thanks
-Aaron
Ok, the first problem is easy, I just forgot to get a perpendicular distance to the force, so it works fine now.
As for the second problem, I was thinking about just balancing the Fx, Fy, Ma, Md, and Me, but that doesn't seem to work either. Any suggestions would be appreciated.
Is [tex]N_D[/tex] supposed to be an applied force in that drawing?
Can you list the terms you have for the net forces, and net torques, and which point they are about?
Sorry, [tex]N_D[/tex] was an internal force from the collar. Thanks anyway, but I managed to figure this one out.
  • · Replies 29 ·
16K
  • · Replies 16 ·
