Small part of a larger problem
  • Thread starter Thread starter efekwulsemmay
The original poster attempts to understand how to manipulate the expression \(\frac{9}{x+h}\) in the context of a larger limits problem, specifically whether it can be expressed as \(\frac{9}{x} + ?\
  • Some participants question the feasibility of transforming \(\frac{9}{x+h}\) into a form involving \(\frac{9}{x}\), discussing the implications of shifting the graph and the properties of fractions. Others suggest that a common denominator could be used to explore the relationship between the two expressions.
Participants are engaged in exploring different interpretations of the problem. Some guidance has been offered regarding the use of common denominators and the implications of shifting graphs, but there is no explicit consensus on the best approach.
The discussion is framed within the constraints of a homework problem, with an emphasis on understanding rather than providing direct solutions.
efekwulsemmay
I am trying to figure out of [tex]\frac{9}{x+h}[/tex] can be split into some thing like
[tex]\frac{9}{x} + ?[/tex]
None
I am not sure what to do. I am trying to do this as part of a larger limits problem.
I don't believe you can change one to the other. The difference between 9/(x + h) and 9/x is that the first is shifted -h units to the left of the graph of 9/x. 9/x + something would shift the graph of 9/x up something units.
You would need to add it to a fraction whose denominator 'a' had the property xa = x + h, or a = (x + h)/x. Unfortunately, there is no fraction that you can add that will not affect the numerator as well.
Damn, ok thanks for your help, both of you.
What you can do is get a common denominator and subtract fractions.
[tex]\frac{9}{x+h}- \frac{9}{x}= \frac{9x}{x(x+h)}- \frac{9(x+h)}{x(x+h)}[/tex]
[tex]= \frac{9x- 9(x+h)}{x(x+h)}= \frac{-9h}{x(x+h)}[/tex]
and you should be able to complete the derivative.
Ahhhhh, I see said the blind man to the deaf dog with no ears. Thank you!
Btw how did you figure out that that's what I was trying to do? That was pretty amazing. :D
Hey, after some time here you get used to figuring out what people are really asking!
  • · Replies 21 ·
  • · Replies 20 ·
  • · Replies 23 ·
