| Thread Closed |
Order of this reaction? |
Share Thread | Thread Tools |
| Nov4-09, 09:53 PM | #1 |
In a reaction between ozone and an organic species, the observed rate was found to depend only on the concentration of ozone at 298 K. Using the data below, determine the order of this reaction and the rate constant (include units). Time (s) |Ozone conc (molecules/cm3) 0 | 4.311×1015 50 | 2.890×1015 100 | 2.036×1015 150 | 1.435×1015 200 | 0.995×1015 250 | 0.689×1015 2. Relevant equations 3. The attempt at a solution Is it first order? I plotted the graph of ln[O3] vs. time on excel and that was a straight line. Also to find k, do I use ln[A]t = ln[A]o - kt? If I use this equation, which value do I use for [A]t?--because the value of k differs slightly for different values. |
| Nov10-09, 11:55 AM | #2 |
When contemplating whether the reaction is first order or not, I would advise taking a graphical approach. Try to imagine what a graph would look like if the line had an equation of a first order reaction versus a second order reaction. Perhaps you may even want to try looking at the graphic behaviour of higher order reactions although the first two may suffice.
Now, when you are determining the value of [A]t, you have to understand that any point on the line works. "HOWEVER," you must use a point on the graph that you have created. Don't forget that when you are creating a line of best fit, you are assuming only the points on that line are relevant, not the points away from the line that helped form it. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Order of this reaction?
| First Order Reaction calculation | Biology, Chemistry & Other Homework | 2 | ||
| What is the order of reaction for Phenolphthalein? | Biology, Chemistry & Other Homework | 3 | ||
| Reaction Order Question | Biology, Chemistry & Other Homework | 0 | ||
| First Order Reaction | Biology, Chemistry & Other Homework | 1 | ||
| Order of reaction | Chemistry | 1 | ||
