Projectile motion, water cannon into storage tank
The problem involves a water hose filling a cylindrical storage tank by shooting water at a 45-degree angle from a distance of 6D away. The goal is to determine the range of launch speeds for the water to enter the tank, considering the tank's dimensions and ignoring air resistance.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the projectile motion of water and its parabolic trajectory, questioning the conditions under which the water will enter the tank. There is an exploration of time calculations based on maximum height and horizontal velocity, as well as the need to consider the downward trajectory of the water.
Some participants are attempting to derive equations of motion for the projectile, while others are questioning the correctness of initial assumptions regarding the trajectory and time calculations. There is a recognition of the need to ensure that the water is on a downward path when entering the tank.
Participants note the importance of the angle of launch and the distance from the tank, as well as the implications of the water's trajectory on the calculations. There is an acknowledgment of the need for clarity in the equations used to describe the motion.
casemeister06
A water hose is used to fill a large cylindrical storage tank of diameter D and height 2D. The hose shoots water at 45 degrees above the horizontal from the same level as the base of the tank and is at a distance 6D away. For what range of launch speeds will the water enter the tank? ignore air resistance and express answer in terms of D and g
Vy=Vosin[tex]\alpha[/tex]-gt
y = (Vosin[tex]\alpha[/tex])t - 1/2 gt2
x = (Vocos[tex]\alpha[/tex])t
v[tex]_{0}[/tex]
I see there will be 2 unknowns, time and initial velocity. So I solved for time when the water is at its max height where Vy = 0.
[tex]Vy = Vosin45 - gt[/tex]
[tex]0 = Vo sin45 - gt[/tex]
[tex]gt = Vo sin45[/tex]
[tex]t= (Vo sin45)/g[/tex]
Now, plug t into the height equation to solve for Vo
2D = (Vosin45)((Vosin45)/g)) - 1/2 g((Vosin45)/g))2
2D = ((Vosin45)^2)/g) - 1/2((Vosin45)^2/g))
2D = 1/2 (((Vosin45)^2)/g)
4Dg = ((Vosin45)^2)
[tex]\sqrt{4Dg}[/tex] = ((Vosin45))
Vo = 2D/sin45
now plug Vo from the previous equation and t into the distance formula for both 6D and 7D to get the range.
for 6D:
6D = ((2Dcos45)/sin45)((Vosin45)/g)
the sin45's cancel...
6D = (2Dcos45/g)Vo
3Dg =Vo cos45
3Dg/Cos45 = Vo
for 7D i did the same and my final result was:
(7/2 Dg)/cos45 = VoI don't really know if its right. I have a feeling it won't make it into the container for whatever reason.
I have this same exact problem. How should I go about solving it?
The water will follow a parabolic trajectory from the hose, so it will be on the "downside" of the curve when it enters the top of the tank (arching over the front lip). There are two critical trajectories. The first is where the water is hitting the front lip of the vat, and the second is where it is hitting the back lip.
Can you write the equations of motion for projectiles fired at 45 degrees from the specified distance and passing through those points?
You might find it convenient to know that sin(45) = cos(45) = sqrt(2)/2.
This is not right. For the stream of water to land inside the tank, the water must be on a downward trajectory. Therefore, Vy must be non-zero.
Instead, calculate t based on the horizontal velocity, which we know does not change.
casemeister06 said:
y = (VosinLaTeX Code: \\alpha )t - 1/2 gt2
4Dg = ((Vosin45)^2)
LaTeX Code: \\sqrt{4Dg} = ((Vosin45))
Vo = 2D/sin45
In addition, your last step is incorrect. You should have come up with
[tex]V_o = \frac{2\sqrt{Dg}}{\sin{45^\circ}}[/tex]
which simplifies to [itex]V_o = 2\sqrt{2Dg}[/tex] since<br /> <br /> [tex]\sin{45^\circ} = \frac{\sqrt{2}}{2}[/tex][/itex]
13K
