How Does Energy Density Change with Scale Factor in Cosmology?
  • Thread starter Thread starter cosmoshadow
    Cosmology Fluid
The discussion revolves around the fluid equation in cosmology, specifically how energy density (\(\epsilon\)) changes with the scale factor (\(a(t)\)). The original poster presents the equation and attempts to manipulate it to express \(\epsilon\) in terms of \(a(t)\), referencing the equation of state.
  • Mathematical reasoning, Problem interpretation
  • The original poster attempts to rearrange the fluid equation but expresses uncertainty about the next steps to derive the desired form of \(\epsilon\). Other participants question the clarity of the operations involved and suggest looking at the differential equation formed from the rearrangement.
The discussion is ongoing, with participants providing insights into the manipulation of the equation. Some guidance has been offered regarding eliminating time-dependence and integrating the resulting differential equation, but no consensus or complete solution has been reached.
Participants are navigating the complexities of differential equations in cosmology, with specific attention to the implications of the equation of state. There may be assumptions about the familiarity with integration techniques and differential equations that are not explicitly stated.
cosmoshadow
The fluid equation in cosmology is given as:
[tex]\dot{\epsilon}[/tex] + 3*([tex]\dot{a}[/tex]/a)*([tex]\epsilon[/tex]+P) = 0
Where [tex]\epsilon[/tex] is the energy density and a(t) is a scale factor.
Using the equation of state, P = w*[tex]\epsilon[/tex], show how [tex]\epsilon[/tex] change with a(t).
I can solve for the equation to the point where I re-arrange it to look like this:
[tex]\dot{\epsilon}[/tex]/[tex]\epsilon[/tex] = -3*(1+w)*([tex]\dot{a}[/tex]/a)
I do not know how to proceed from here. I know that this equation is supposed to end up like this,
[tex]\epsilon<sub>w</sub>(a)[/tex] = [tex]\epsilon<sub>w,0</sub>[/tex]*a-3*(1+w)
but I do not know how to get to this point. Can someone assist me please?
can someone take a look at this? I'm pretty sure its a simple operation that I'm failing to realize.
bump?
You have your equation
[tex]\frac{\dot\epsilon}{\epsilon} = -3(w+1)\frac{\dot a}{a}[/tex]
From here you can eliminate the time-dependence
[tex]\frac{d\epsilon}{\epsilon} = -3(w+1)\frac{da}{a}[/tex]
and this is a differential equation involving just [tex]\epsilon[/tex] and [tex]a[/tex] you can solve by integrating both sides
