| Thread Closed |
Quantum Operators (or just operators in general) |
Share Thread | Thread Tools |
| Feb15-10, 04:02 PM | #1 |
[tex]\phi_1[/tex] and [tex]\phi_2[/tex] are normalized eigenfunctions of observable A which are degenerate, and hence not necessarily orthogonal, if <[tex]\phi_1[/tex] | [tex]\phi_2[/tex]> = c and c is real, find linear combos of [tex]\phi_1[/tex] and [tex]\phi_2[/tex] which are normalized and orthogonal to: a) [tex]\phi_1[/tex]; b) [tex]\phi_1[/tex]+[tex]\phi_2[/tex] 2. Relevant equations Non? 3. The attempt at a solution attempt at a) from the fact that <[tex]\phi_1[/tex] | a[tex]\phi_1[/tex] + b[tex]\phi_2[/tex]> = 0 i got a + bc = 0 if I let b = 1, then a = -c, then if i use the fact that it must be normalised: <a[tex]\phi_1[/tex] + b[tex]\phi_2[/tex] | a[tex]\phi_1[/tex] + b[tex]\phi_2[/tex]> = 1, both equations cant be satisfied simultaneously? Where am i going wrong? thanks 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| Feb15-10, 04:24 PM | #2 |
| Feb15-10, 04:26 PM | #3 |
You could try using Gram-Schmidt to solve the problem.
| Feb15-10, 04:30 PM | #4 |
Quantum Operators (or just operators in general)Isn't the normalization taken into account when I did: <a[tex]\phi_1[/tex] + b[tex]\phi_2[/tex] | a[tex]\phi_1[/tex] + b[tex]\phi_2[/tex]> = 1 Sorry I havent really gotten grips with this operator stuff. |
| Feb15-10, 04:40 PM | #5 |
It has nothing to do with operators; it has to do with normalization. For a two-component linear combination, a normalized wavefunction (with real coefficients) is always
[tex]a|\phi_1>+\sqrt{1-a^2}| \phi_2>[/tex] Now pick a = 1 and see what happens to this linear combination. |
| Feb15-10, 04:48 PM | #6 |
How is this proved? |
| Feb15-10, 04:50 PM | #7 |
| Feb15-10, 04:52 PM | #8 |
Correct. That's only if they are orthogonal. My mistake.
*** Correction *** Should read orthonormal. |
| Feb15-10, 04:52 PM | #9 |
| Feb15-10, 04:56 PM | #10 |
However, you have
a + bc = 0 and the normalization condition a2 + b2 = 1 Two equations and two unknowns. It is picking b =1 that you cannot do. |
| Feb15-10, 04:59 PM | #11 |
a2 + b2 = 1 Where did you get that from? the cross terms in normalization don't vanish? |
| Feb15-10, 05:03 PM | #12 |
| Feb15-10, 05:04 PM | #13 |
| Feb15-10, 05:13 PM | #14 |
You have two choices: If you set b=1, then a=-c, and the linear combination you have is orthogonal, but not normalized. So you have to normalize -c|1>+|2>. If you don't set b=1, you can eliminate a using a+bc=0 and then solve for b using the normalization condition. What you can't do is require b=1 in the normalized solution. That's where you're running into problems.
| Feb15-10, 05:16 PM | #15 |
Yeah, I realize now that I cannot do that, is it possible to do it without resorting to the Gram-Schmit process? Kuruman was suggesting using simultaneous equations, but are the coefficients a and b necessarily real? |
| Feb15-10, 05:21 PM | #16 |
You don't need to use Gram-Schmidt. It just seemed like an obvious method to me when I first read the problem.
Just pick an approach and normalize the resulting state the usual way. |
| Feb15-10, 05:21 PM | #17 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Quantum Operators (or just operators in general)
| proof help - quantum operators | Advanced Physics Homework | 5 | ||
| Operators in quantum mechanics | Linear & Abstract Algebra | 4 | ||
| quantum mechanical operators. | Quantum Physics | 7 | ||
| Quantum mechanics and operators? | General Physics | 15 | ||
| Quantum Mechanics => Operators | Introductory Physics Homework | 1 | ||
