| Thread Closed |
Magnetism (Current-Carrying Wires) |
Share Thread | Thread Tools |
| Feb22-10, 09:52 PM | #1 |
Two straight wires, each with a resistance of 0.170 ohm and a length of 3.90m, are lying parallel to each other on a smooth horizontal table. Their ends are connected by identical, non-conducting, light springs, each spring having an unstretched length of 1.08 cm. A wire of negligible resistance connects the wires at one end. When a switch is closed to connect a battery with a voltage of 49.0 V between the other ends of the wires, the wires move apart and come to rest with a separation of 1.57 cm Question: Find the force constants of the springs. 2. Relevant equations F=-kx (F/L)=(u0I1I2)/2Pi r 3. The attempt at a solution I tried to solve using the equations above for K, and does not work. |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Feb23-10, 05:19 AM | #2 |
Did you modify the k in the spring equation to take into account the presence of both springs in a parallel arrangement?
| Feb24-10, 01:27 AM | #3 |
Yes I did. This is what I got:
F=-2kx (F/L)=(uI^2)/(2pi a) k=(uI^2L)/(4piax) I tried solving this, but got wrong answers. What I did: u=1.26e-6 (Constant given to use) I=144.1176 (Combining resistors in series and finding current) L=3.90 (Length of the wire) a=0.0157 (Seperation of the wires) x=0.0049 (stretch of the spring) Thats what I use, and I got 106 N/m. Can you verify that please? |
| Feb24-10, 02:07 AM | #4 |
due to passing of current the magnetic field is created in the rods hence we know the formula F=vlb from that u can find the force and from F=kx u can find the spring constant
| Feb24-10, 11:18 AM | #5 |
So what I have is correct? Can you check?
| Feb24-10, 10:04 PM | #7 |
Thank you. :)
| Thread Closed |
| Thread Tools | |
Similar Threads for: Magnetism (Current-Carrying Wires)
| Straight wires carrying current | Introductory Physics Homework | 6 | ||
| Net Magnetic Field of current carrying wires: | Introductory Physics Homework | 0 | ||
| current carrying wires | Introductory Physics Homework | 1 | ||
| Magnetism and Current Carrying wires (???) | Introductory Physics Homework | 5 | ||
| Current Carrying Wires--No force b/t them? | General Physics | 3 | ||
