Current flowing through a copper wire
The discussion focuses on calculating the minimum diameter of a copper wire required to carry a current of 20 A without exceeding a power dissipation of 2 watts per meter. The resistivity of copper is given as ρ=1.72 x 10^-8 Ωm. The calculations reveal that the minimum radius needed is approximately 1.046 mm. Additionally, the density of charge carriers in copper is calculated to be 8.535 x 10^28 charge carriers/m^3, and the drift velocity of electrons in a wire with a radius of 1 mm carrying 1 A of current is determined to be 4.257 m/s.
  • Understanding of electrical resistance and power dissipation
  • Familiarity with the resistivity of materials, specifically copper
  • Knowledge of Avogadro's number and its application in calculating charge carrier density
  • Basic principles of drift velocity in conductive materials
  • Research the formula for calculating electrical resistance in conductors
  • Learn about the relationship between current, voltage, and resistance (Ohm's Law)
  • Explore the concept of drift velocity and its significance in electrical engineering
  • Study the properties of copper and its applications in electrical wiring
Electrical engineers, physics students, and anyone involved in designing or analyzing electrical wiring systems will benefit from this discussion.
sweetdion
1. The wiring in a house must have low enough resistance so that it does not heat up too much while current is flowing. A particular copper wire needs to carry 20 A of current, and it must not dissipate more than 2 watts of power per meter of length. The resistivity of copper is ρ=1.72 x 10^-8 Ωm
a) What is the minimum diameter that the wire must have so that it doesn't heat up too much?
b) The density of copper metal is 9 g/cm^3, and the atomic mass is 63.5 g/mole. Avagadro's number is 6.022 x 10^23 atoms/mole. Assume one charge carrier per atom and determine the density of charge carries n (number of charge carriers per cubic meter) in copper.
c) A copper wire with circular cross-section with radius r=1mm carriers 1 A of current. Determine the drift velocity of the electrons in the wire.
A=ρL/R A=π r^2 P = I^2R R=V/I P=V^2/R
v=I/nqA
a) from A = pL/R
r=squareroot(A/pi)=squareroot(pL/PiR)=1.046 mm
b) d=9g/cm^3 x 1mol/63.5g x 6.022x10^23 charge carriers/1mol x 100 cm^3/1 m^3 = 8.535 charge carriers/m^3
c) r = .001 m
I = 1 A
v= I/nqA = 1/(8.545)(1.6x10^-19)(1.72x10^-8*1 m/.001m)= 4.257 m/s
I was unsure about the coversion from cm^3 to m^3
Also, I'm unsure about the length I am supposed to use. Should it be 1 m because the power was given to me in watts/meter?
Thanks in advance,
--sweetdion
v=I/nqA
a) from A = pL/R
We were not given a value for R; you have left out some steps in how you got to your 1.046 mm answer.
You have neglected the 1023 part of Avogadro's number. Also, your units conversion is wrong:
If (1 m) = (100 cm), then
(1 m)^3 = (100 cm)^3 = ____ cm^3 ?
c) r = .001 m
I = 1 A
Thanks in advance,
--sweetdion
Yes, it is easiest to use 1 m and 2 W to solve the problem. Alternatively, using 2 m and 4 W, or 3 m and 6 W, etc., should give the same answer, since they all use 2 W per m.
to find R i did R=V/I=0.1V/20A = .005Ω then I plugged it into get the right answer
thanks for your help!
