Mechanical Failure of a Truncated Cone
The discussion focuses on calculating the failure point of a truncated cone subjected to uniaxial stress, specifically under static loading conditions. Participants explore the necessary data, material properties, and relevant formulas needed for analysis, considering the cone's geometry and construction material.
  • One participant inquires about the data required to calculate the failure point of a truncated cone under a downward uniaxial stress of approximately 30 tonnes, constructed from plastic.
  • Another participant suggests that material properties, dimensions, and loading conditions are essential for the calculations, and emphasizes the importance of establishing a failure criterion.
  • A third participant specifies that the material is likely ABS reinforced with glass fibers, notes the cone is hollow, and indicates that failure occurs when it can no longer elastically return to its shape.
  • Concerns about buckling are raised, with a participant noting that the cone behaves as a thin-walled shell loaded eccentrically due to its geometry.
  • A participant provides specific dimensions for the cone, including a 1000mm diameter base, 850mm diameter top, 3500mm height, and 50mm wall thickness.
Participants express varying views on the factors influencing failure, including material properties and loading conditions. There is no consensus on a specific approach or formula, and the discussion remains unresolved regarding the exact calculations needed.
Participants have not fully established assumptions regarding the loading conditions and failure criteria, and there is uncertainty about the implications of the cone's geometry on its structural integrity.
DougieB39
What data do you need to calculate the failure point of a truncated cone when it is under uniaxial stress acting downward on the cone? The cone will be under stresses of roughly 30 tonnes and probably constructed of plastic.
Thanks,
Well let's see,
You need the material or its properties, the dimensions of the cone including whether it is solid or hollow, a knowledge of the loading conditions at the top to determine any eccentric loading.
Finally you need to establish you failure criterion.
Remember that with the conditions described, unless the cone is slender enough to buckle, the top slice will fail plastically before the slice underneath it and so on. So a squat cone will squash down plastically until either it is flat or it can support the load stress at a particular cross section.
The material will probably be ABS reinforced with galss fibres, the cone will be hollow and the load at the top will just be a static load evenly distributed.
Failure conditions will be after it reaches the point that it won't elastically return to its shape.
I'm more interested it what formulae you would need to use and what material properties will need to be found/calculated.
thanks again
Since gravity is vertical and the sides of your cone are not, you have a thin walled shell loaded eccentrically, rather than axially. You will definitely have to consider buckling. The dimensions become rather critical.
1000m dia. base, 850mm dia. top, 3500mm height, 50mm wall thickness
Thanks
  • · Replies 69 ·
  • · Replies 26 ·
9K
